Hi pipiche,
Just for your information: this was the first time since very long that the Z4D plugin update from .018 to .019 failed via the WebUI. However, by updating manually using the commands in your wiki, I succeeded updating the plugin. I don’t know why this happened. Just to let you know.
(Latest Domoticz on Raspberry Pi 4 running Raspberry PiOS Bullseye)
Z4D update from 7.1.018 to 0.19
Re: Z4D update from 7.1.018 to 0.19
Can you share the plugin logs ? ( they are in logs folder)
Wiki is available here.
Zigbee for Domoticz FAQ
Found the issue, will issue an update (but upfortunatly) manual step will be required
Unfortunately since 7.1.018 the WebUI plugin update feature do not work. You need to upgrade manually the plugin by doing
and then restarting Domoticz
Shame on me
git checkout stable7
git pull
sudo python3 -m pip install -r requirements.txt --upgrade
Shame on me
Thank you for your fast reaction. The manual installation is an easy work-around, but it’s good to know that it wasn’t me, or my configuration. So, I am now at .019 using the manual installation as mentioned also in your previous post. Everybody happy
Users browsing this forum: Bing [Bot] and 0 guests
