Z4D 3-phase energy monitor
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
Hi everybody.
I'm using Zigbee4Domoticz and need 3 phase energy monitor (Smth like this)
The surch gives nothing.
has anyone had any experience with such a device?
Any link on Aliexpress.
Thanks a lot.
P.S. zigbee.blakadder.com/z4d.html - is it alive?
pipiche
Re: Z4D 3-phase energy monitor
Post by pipiche »
I'm using the native Owon one and it works like a charm. The one you pointed out which is Tuya OEM has been also integrated on the plugin and works well.
Wiki is available here.
Zigbee for Domoticz FAQ
habahabahaba
Owon is not available on Ali :( Broken link
Domoticz version: 2024.7
I use something similar. The only issue I have is that the Energy counter is not counting backwards when negative currents (eg solar is producing more the usage). So I use the compute mode of the domoticz device.
https://github.com/zigbeefordomoticz/z4 ... /issues/38
I saw that there was a fix in
Dec. 2024 - stable7.1.015 (2024.07) [Issue] - fix bad handling of Owon PC321 negative power
but that did not help for me.
psubiaco
Post by psubiaco »
If wired solution are accepted, you can try with DTS238 ZN/S (cheap, Modbus (RS485), works perfectly, with domoticz plugin) or SDM630: they are class-1 meters with 1% accuracy. Check Domoticz wiki -> Plugins
Paolo
habahabahaba
OK, thanks everybody. Will think
pipiche
Post by pipiche »
habahabahaba
pipiche wrote: Tuesday 28 January 2025 10:44 https://fr.aliexpress.com/item/10050047 ... pt=glo2fra
https://fr.aliexpress.com/item/10050059 ... pt=glo2fra
That's a Wifi, but they also refer to Zigbee ...
Thanks a lot!
