Anybody got a clue why the heater in the heater in the garage is not turning on?
Today all three conditions were met; temp below 8 degrees, solarpanels producing more than 1000 watts and heater was off.
Blockly script not working
WilcoEHV
- Domoticz version: 2025.1
Raspberry 3B with Raspberry PI OS
Re: Blockly script not working
What is the trigger for the script? Should be device or time or All (not preferred).
It seems you need the if-then block (without the blue gearwheel).
You used the else-if block....
willemd
- Domoticz version: 2024.1
Your script tests for actuals > 1000 kWh while your mail mentions > 1000 Watts?WilcoEHV wrote: Friday 10 January 2025 19:47 Hi,
Which unit does your sensor show? Factor 1000?
WilcoEHV
Thx for the replies!
I changed the if then block to one without gearwheel.
Hopefully this works!!
Triggers are in the script.
Solaredge reports watts and kwh (although i named it kWh).
I've got it on a different system where it's responding to watts.
WilcoEHV
An update; the script is running as expected by now!
Thx for the help.
Thx for the help.
