Sent CPU temperature from Proxmox to Domoticz Topic is solved
SunHopper
Post by SunHopper »
With help of google I made a Python scrip for sending my server CPU temperature running PROXMOX VM to a virtual sensor
The temperature is updated in the file : /sys/class/thermal/thermal_zone0/temp
Only reading the first 2 digits on the first line.
Send this value to a virtual sensor in Domoticz every 5 minutes.
Note: This script has to run on the Proxmox server itself !! Not on the OS Domoticz runs on !!!!!
import os
import re
import requests
import time
import sys
while True:
    file = open('/sys/class/thermal/thermal_zone0/temp', 'r')
    first_line = file.readline(2).strip()
# Close the file
    file.close()
    domoticzserver = "192.168.178.37:8080"
    idx_temp = "373"  # Put youre own IDX here of the virtual sensor
    val_temp = first_line
    res = requests.get(
        "http://"
        + domoticzserver
        + "/json.htm?type=command&param=udevice&idx="
        + idx_temp
        + "&nvalue=0&svalue="
        + val_temp
    time.sleep(300)  # send every 5 minutes
Last edited by SunHopper on Saturday 11 January 2025 10:44, edited 2 times in total.
Domoticz version: 2024.7
Re: Sent CPU temperature from Proxmox to Domoticz
Normal Domoticz motherboard sensor gateway is not working in Proxmox environment?
SunHopper
Post by SunHopper »
Thats right. Domoticz runs on Ubuntu in a Proxmox VM.
Domoticz can't access the server sensors.
With this script running on the proxmox server itself it sends the CPU temperature to the IP address od Domoticz.
This way I'm able to monitor and get an alarm on Telegram when my CPU temperature is getting to high (summer time).
sloeber70
Domoticz version: latest
Post by sloeber70 »
Hi.
Works fine!!
Do I need to create a crontab for this python file?
How can I check that this process is running and restart it if that would be necessary?
Kind regards.
Kind regards,
Sloeber70
Linux 12 Bookworm standard edition
Domoticz latest beta
sloeber70
Post by sloeber70 »
Hi.
The script runs once and then it stops.. The delay for restarting the query is not working.
So I've altered the script and just remarked the timer and added "quit()". So that the script stops and the process is deleted.
I've added a crontab line so that the script runs every xx minutes (choice).
Crontab:
*/5 * * * * python3 /root/temp2domoticz.py
Script:
## start script ##
import os
import re
import requests
import time
import sys
while True:
file = open('/sys/class/thermal/thermal_zone1/temp', 'r')
# Close the file
file.close()
domoticzserver = "10.10.3.2:9080"
idx_temp = "4856" # Put youre own IDX here of the virtual sensor
res = requests.get(
"http://"
+ domoticzserver
+ idx_temp
+ val_temp
#time.sleep(5) # wait 5 seconds
quit()
## end script ##
See the result in attachment
Kind regards,
Sloeber70
sloeber70
Post by sloeber70 »
Kind regards,
Sloeber70
SunHopper
Post by SunHopper »
@sloeber my script keeps running I started the script ending with & like: python3 /home/domoticz/domoticzCPU.py &
Added this to contrab for auto startup.
Nice to see it works for you :D
