Display problem in phpBB
There is a small cosmetic problem in phpBB.
When I change the page number, display is not updated and increment does not work.
Tested with different browsers.
- gizmocuz
Re: Display problem in phpBB
You mean when you press '5', it does not highlight 5? That happens here...
Maybe clear your browser cache, try in private mode?
Using 'Edge' here
Using 'Edge' here
- Egregius
- Domoticz version: v2024.7
I see the same issue in Chrome and Safari on MacOS and Chrome, Firefox and Edge on Windows. Each test was done in a private browsing window.
- Domoticz version: 2024.7
Works for me on Android Firefox
Additional, it works correct when logged in.
When NOT logged it shows always page 1 after selecting another page.
Logged or not, I get the same issue
- andreo
- Domoticz version: 2024.3
I've been having this same problem ever since the snowflakes and Santa hats came into the picture
Latest version of Domoticz and more running on Docker|Raspberry Pi 4-B 8GB Bookworm|RF-Link|Klik Aan Klik Uit|Nefit easy|ESPeasy|P1 power meter|S0PCM-5 through Ser2Net|Alecto WS5500|FrtizBox|Satel Integra|Solis
Greetz Andre.
Greetz Andre.
Those are switched off now.... Is it working again?
- Egregius
You sure? If I open a private window I still get the snow. Used a private window because that's disabled in my profile.
- gizmocuz
It's still freezing outside, changes of snow are there....
Ok, seems when not logged it, there is an issue with the bullets indeed.
So, the solution is to login for now...
- Egregius
It also happens when logged in...
- HansieNL
Brrr... I tried to find the "Disable snowing" button, but without succes
Logged in Firefox Focus on iPad and problem too with the bullets. Looks like it happens only on frontpage.
Blah blah blah
- andreo
After deleting the cache the problem persists. it makes no difference whether you are logged in or not.
Greetz Andre.
Greetz Andre.
It looks to be a bug in phpBB (or a phpBB plugin) so hopefully it will be solved in a newer version of the forum soon.
