timer with except
pierrotori
Domoticz version: 2024.4
timer with except
Post by pierrotori »
i would like to create a timer as 'every 5 minutes except at 02:00 and except at 06:00'
but the first exception is right but not the second
What is the good syntax in the rule ?
Pierrotori
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
Domoticz version: 2025.1
Re: timer with except
Probably but not tested
every 5 minutes except at 02:00,06:00
pierrotori
i found this solution , to have the trigger name in the script
local time_today = 'every 5 minutes except at 02:00-06:00' -- periode activité
local time_calme = 'every 5 minutes between 02:00 and 06:00' -- periode calme zero consommation
This is not what you asked for in your first message but hey, if it works, it works.....
pierrotori
exactly, i didn't find a correct syntax . i have this solution to bypass
