LUA script not triggering other script
manjh
Post by manjh »
I have a LUA script that is triggered by a changed user variable. Works great when I manually change the variable.
Then I have another script that is triggered by time, and in some circumstances changes the user variable in order to trigger the first script.
I can see the user variable being changed by that second script, but the first script is NOT triggered.
Is this an error on my side? Or a bug Or is it "as designed"?
Hans
lost
Re: LUA script not triggering other script
Post by lost »
manjh wrote: Monday 30 December 2024 16:41 I can see the user variable being changed by that second script, but the first script is NOT triggered.
I remember I had this kind of issue... Only solution I found at the time was doing the change action using HTTP/JSON API from Lua, not table driven action as usual.
May dig in my scripts to better remember this if needed but your observation ringed a bell...
jvdz
Domoticz version: 4.107
Post by jvdz »
Correct, and this is what sort of explains it:
Events
User variables can trigger events, and can also be read and updated through events. Whenever a variable is changed through the API or the webinterface, the event system is triggered. In Lua, scripts in the format script_variable_name.lua will be run, and Blockly will be checked for the relevant variable as well. In the event logic variables can be used and/or updated, but not added. Therefore if you wish to use variables in events, you have to create them first in the user interface. Note that setting a variable through an event does not trigger the event logic again since this can create a nasty loop.
For more info on using variables in events see Events
Using a JSON/API link for updating solves that issue.
manjh
Post by manjh »
OK, I guess I can try that.
Can some kind soul point me at an example of running a JSON command from within a LUA script? :oops:
Hans
lost
Post by lost »
Not exactly fits your needs because this was for updating a virtual sensor (for electric consumption data) but, to sum-up, use curl with the same arguments you would use trying using a web browser:
-- Domoticz base url
urlDz='http://127.0.1.1:8080'
-- Update virtual sensor (using normal 'UpdateDevice' or http/JSON if useHttpApi set to true),
-- take care only useHttpApi will trigger other device script(s) on a virtual sensor/meter update.
-- Uses urlDz as global base URL variable for Domoticz (f.i: urlDz='http://127.0.1.1:8080').
local function updateNum(dev, value1, useHttpApi)
    if (useHttpApi == true) then
        local cmd = string.format(urlDz..'/json.htm?type=command&param=udevice&idx=%d&svalue=%d', otherdevices_idx[dev], math.floor(value1))
        --print(cmd) -- DEBUG
        -- OpenURL (being async) may trigger multiple events if base HW retriggers before API call is processed => use curl.
        -- table.insert (commandArray, { ['OpenURL'] = cmd } )
        local handle = assert(io.popen('curl --retry 1 --connect-timeout 1 -m 3 \"'..cmd..'\"'))
        result = handle:read('*all')
        -- Returned JSON format : {"status" : "OK","title" : "Update Device"}
        handle:close()
        if not string.find(tostring(result), "OK") then
            print('ERROR : '..cmd)
            print('ERROR : updateNum/useHttpApi returned '..tostring(result))
        local cmd = string.format('%d|0|%d', otherdevices_idx[dev], math.floor(value1))
        table.insert (commandArray, { ['UpdateDevice'] = cmd } )
In this function, I can use normal commandArray table driven update (if useHttpApi parameter is set to false at function call) or http/json immediate update (if useHttpApi is true).
I use this for virtual kW meters that record true max power (in 10mn time-slices, to avoid domoticz only sampling instant values per 5mn slices in DB/Graphs, so mostly missing true min/max for devices with values that can change a lot in 5mn: Good for temperature, very very bad for power data!) from a power-meter that gets my whole home consumption. As I also use this virtual device to do some load limiting (shutting down heavy power drainers if needed to avoid overlapping my contract power budget & home shutdown), I needed something that triggers other scripts (setting power drainers off for some time) on current time slice intermediate max values & ran in similar issue as yours at the time.
The important call there is the
with prebuilt cmd string according to http/json API:
API documented here for all possible actions:
https://wiki.domoticz.com/Domoticz_API/JSON_URL%27s
All stuff around is just to see if command response from domoticz is OK processing curl command (you may also need to install curl if not present on system) text answer.
As I said, you can test the command from a web browser, just use the LAN IP of your domoticz host instead of the localhost from urlDz in script.
Take care using 'OpenURL' that can be CommandArray driven is commented: This was not working correctly, as stated in Lua code comments. So no way to avoid curl or similar system command...
Domoticz conception try to be a bit foolproof & avoid infinite loops that may result from incorrect use/scripting with such behavior. See also master/slave devices concept that is made almost useless for all in Domoticz to prevent misuses some may do, with no possible workaround than script all devices relationships! Here at least there is a solution.
manjh
Post by manjh »
OK, thanks. Got it! :)
Hans
