Hi!
My zwave network was very messy. So I decided to completely start over.
Removed all devices from dz
Removed z2m AD from dz
Via zwavejs-ui removed all nodes and paired them again
I expected all old data should be removed (not true)
Once I accepted new devices by dz settings they popped up but.... all old names / node data. It appeared this came from the button in hardware on the z2m AD hardware.
I can't get rid off that data as shown down below. Any suggestion?
TIA
Bart
[solved] how to remove data from hardware z2m controller in DZ
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- gizmocuz
Re: how to remove data from hardware z2m controller in DZ
In Domoticz, select the MQTT hardware, and press the Delete button to delete it (and all devices)
Next press the ADD button to add it again
If you talk about old config objects from zigbee2mqtt/zwavejs, these have to be removed by hand if that is not done by the software itself.
You can use MQTT Explorer for this, next delete/add the hardware again in Domoticz
- Domoticz version: 2024.7
It seems to be an issue of retained mqtt auto discover config topics. See the wiki how to delete those retained topics https://wiki.domoticz.com/MQTT#Delete_retained_topic
thanks! It was indeed a 'retain' problem.
All seems OK now.
All seems OK now.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
