I am wondering if when using the `heartbeat` function in the domoticz module (see https://wiki.domoticz.com/Developing_a_ ... llable_API) inside of a loop, takes into account the execution time of the code between consecutive iterations? In essence, I am wondering if heartbeat can be considered equivalent to this type of solution https://stackoverflow.com/questions/725 ... s#72587779 where timing of the execution is critical/accounted for. Thanks.
SOLVED: Does heartbeat takes into acount execution time?
averter
- Domoticz version: 2024.4
Last edited by averter on Saturday 28 December 2024 17:01, edited 1 time in total.
- gizmocuz
Re: Does heartbeat takes into acount execution time?
No, it should be executed at every heartbeat interval
But I guess you want to use a timer? You can create your own timers in Python if you want
Or you can set the timer parameters in dzVents scripts
averter
Thanks for your reply.
The main objective is to read values from an inverter at specific intervals, and I'm using this plugin to do so https://github.com/saidlm/Domoticz-Sola ... 8C8-L251C1
As you can see, the author has used heartbeat to pause between consecutive iterations, and that's why I was wondering if the code could be improved (apparently yes). Thanks again for your help.
- Domoticz version: 2025.1
Re: SOLVED: Does heartbeat takes into acount execution time?
Why do you want it to be so specific that it needs a more precise timer? Is for example every approx 30 seconds not good enough? What goes wrong if it is sometimes 29 or 31 seconds?
averter
The reason is that I'm using a smart EV charger (dombusevse) along with the inverter, and for it to adjust the charging load properly domoticz should have readings from the inverter at every 5-6 seconds. The more precisely the better (less fluctuations).waltervl wrote: Saturday 28 December 2024 18:04 Why do you want it to be so specific that it needs a more precise timer? Is for example every approx 30 seconds not good enough? What goes wrong if it is sometimes 29 or 31 seconds?
Although 5-6 seconds might seem exaggerated, according to the dombusevse's website this is a standard value:
The 6s time (SAE1772 standard) corresponds with the max time that the OBC can use to modify the consumed power in accordance with what is established by the EVSE module
Every 5 or 6 seconds should be handled correctly unless you have a lot running on your system including mqtt.
Execution times of scripts should not exceed a couple of seconds. If not you have programmed the scripts incorrectly. For dzvents scripts look at asynchronous external commands execution, incl openURL().
