Using a library , I can run the following on the command line and the switch works everytime
$ wemo switch "Wemo Switch" on
#!/bin/sh
However, when I added the same to a dummy switch under on action , it does not work reliably
Sometimes it works but more often than not, it doesn't
It's a rather odd issue and the only possibility I can think of is that the actual command takes a long time (5-6 seconds) to execute and the on action times out by then
HHow can I fix this?
