posting data
vespino
posting data
Post by vespino »
I have the following:
        devices = {
            'Wekker',
    execute = function(domoticz, switch)
        domoticz.openURL({
            url = 'https://domain.tld/script',
            method = 'POST',
            postData = {
                idx = switch.idx,
                status = switch.state,
                level = switch.level
My problem is the data isn't POST. I have tried posting the data to my test script using cURL, that does work.
Any tips on how to get this working?
HvdW
Domoticz version: 2023.2
Re: posting data
Post by HvdW »
What about filling in a domain?
What do you see when you open https://domain.tld/script in a browser?
Bugs bug me.
vespino
Re: posting data
Post by vespino »
The script works fine when calling it in the browser. Also Domoticz triggers the script, but the POST values just are empty/absent.
Domoticz version: 2025.1
Re: posting data
What if you replace the switch attributes with text to test?
            postData = {
                idx = '25',
                status = 'On',
                level = '10'
vespino
Re: posting data
Post by vespino »
Same, I tested with the examples found on the wiki page.
Re: posting data
Did you use the curl test from the Domoticz server? Perhaps the server you want to reach is blocked from the Domoticz server?
And what if you set log level to debug?
Add
logging = {
    level = domoticz.LOG_DEBUG,
    marker = "POST Test"
vespino
Re: posting data
Post by vespino »
It isn’t blocked. The script is supposed to create a file and add the POST data to that file. The file is created, however the array is empty.
HvdW
Re: posting data
Post by HvdW »
Test with predefined data
postData = { idx = '25', status = 'On', level = '10' }
vespino wrote: Wednesday 18 December 2024 19:55 The script is supposed to create a file and add the POST data to that file. The file is created, however the array is empty.
 	local yourFile = "/home/pi/nameOfFile.csv"
 	local file = io.open(yourFile, "a")
        file:write(currentDate, ";", moredata,  "\n")
        file:close()
Bugs bug me.
vespino
Re: posting data
Post by vespino »
@hvdw I already tested it like that just to make sure it’s not the data missing that is causing the issue.
Re: posting data
If curl from the Domoticz server work, in theory openUrl() should also work. So please do the curl c from the Domoticz server (you did not explicitly answer my question about this).
vespino
Re: posting data
Post by vespino »
I’m running Domoticz on Docker, logged into the command line and ran the following curl command:
curl -d 'id=9&name=baeldung' https://domain.tld/script
This created file with an array/values that I posted.
Re: posting data
With the debug on you probably can see in the log what is sent as POST, see for example viewtopic.php?p=317025&hilit=Openurl+Post#p317025
habahabahaba
Domoticz version: 2024.4
Re: posting data
Post by habahabahaba »
Wiki
Posting data should be a string.
Is it?
My code is:
domoticz.openURL({
                url = APIURL,
                method = 'POST',
                postData = { msgtoAlice = postString }
            }).afterSec(1)
It works but i have only 1 param to post.
vespino
Re: posting data
Post by vespino »
Data seems to be post:
2024-12-19 18:06:12.217 dzVents: Debug: POST Test: OpenURL: method = POST
2024-12-19 18:06:12.217 dzVents: Debug: POST Test: OpenURL: post data = {"idx":108,"level":15,"status":"On"}
2024-12-19 18:06:12.217 dzVents: Debug: POST Test: OpenURL: headers = !#Content-Type: application/json
2024-12-19 18:06:12.217 dzVents: Debug: POST Test: OpenURL: callback = nil
Data received is still empty though. Could it be the JSON header (that I now notice)?
(This is probably just a stupid thing, so sorry in advance)
Last edited by vespino on Thursday 19 December 2024 18:12, edited 1 time in total.
jvdz
Domoticz version: 4.107
Re: posting data
Post by jvdz »
I would first try to put the data in a quoted string.
Data = "{.....}"
vespino
Re: posting data
Post by vespino »
@jvdz that does do something, but the reason I prefer POST over GET is the code is better readable and this way I can use GET just as well (first world problem)
jvdz
Re: posting data
Post by jvdz »
My only suggestion was to use a proper string instead of lua table not to change post to get!
habahabahaba
Re: posting data
My opinion:
- almost the correct json format except 108 and 15
So every posting param must be a string
Try
postData = {
                idx = tostring(switch.idx),
                level = tostring(switch.level)
vespino
Re: posting data
Post by vespino »
@jvdz I didn’t change post to get, I was referring to the markup. I was hoping to use post so the variables are more clearly visible instead of one long string as with get.
@habahabahaba adding tostring doesn’t make a difference.
habahabahaba
Re: posting data
Made some test with Node-red.
1.
Out:
postData = {
                                idx = 101,
                                status = Off,
                                level = 15,
                                param1 = qweqwe,
                                qwer = werewqr,
                                open = true
In:
{"idx":101,"level":15,"open":true}
Lost some data
2.
Out:
postData = {
                                idx = '101',
                                status = On,
                                level = '15',
                                param1 = 'qweqwe',
                                qwer = 'werewqr',
                                open = 'true'
In:
{"idx":"101","level":"15","open":"true","param1":"qweqwe","qwer":"werewqr"}
Lost 1 param
3.
Out:
postData = {
                                idx = tostring(btn.idx),
                                status = 'On',
                                level = '15',
                                param1 = 'qweqwe',
                                qwer = 'werewqr',
                                open = 'true'
In:
{"idx":"101","level":"15","open":"true","param1":"qweqwe","qwer":"werewqr","status":"On"}
OK
4.
Out:
postData = {
                                status = btn.state,
                                level = '15',
                                param1 = 'qweqwe',
                                qwer = 'werewqr',
                                open = 'true'
In:
OK
So.
Every param have to be a string value and everything works fine.
PS. The params in result JSON string automatically sorted in alphabetical order
PPS And dont add any headers params in domoticz.openUrl - it gives wrong output json format
