I'm in the process of migrating from OPENZWAVE to Zwave JS UI/MQTT
I managed to follow the guideline so that all devices show in Domoticz but they did not function.
I got suck so I decided to readd all the devices.
The procedure is simple.
1. Exclude the device
2. Include the device
3. Enable discovery for the wanted objects (usually dimmer 1)
4. Store
5. Update
6. Rediscover
It has worked very well up until now. All of a sudden I get the below when I try to add a new node or rediscover an existing node.
2024-12-17 06:53:36.634 ERROR MQTT: Mqtt client error connack timeout
Error: connack timeout
at Timeout._onTimeout (/usr/src/app/node_modules/mqtt/src/lib/client.ts:876:23)
at listOnTimeout (node:internal/timers:569:17)
at processTimers (node:internal/timers:512:7)
2024-12-17 06:53:36.723 INFO MQTT: MQTT client closed
2024-12-17 06:53:39.723 INFO MQTT: MQTT client reconnecting
Any Idea what do do?
ERROR MQTT: Mqtt client error connack timeout Topic is solved
- FireWizard
Re: ERROR MQTT: Mqtt client error connack timeout
Can you connect to your broker with MQTT Explorer?
What is the setting of your time-out parameter? Do not use less than 60 secs.
Hi FireWizard,
Thank you for the prompt comment.
Yes. I can connect to the broker with MQTT Explorer.
Which timeout parameter are you referring to? Where is it set?
In Zwave JS UI I only find "MQTT/Reconnect period (ms)" I use the defaut 3000ms.
I stopped both Mosquitto and Zwave JS UI.
Then I started Mosqutto before I started Zwave JS UI.
Now it is working again.
Previously I tried to reboot the system but that did not help. So, I guess there is a dependency on the start order of the servives.
Is there a better expalnation?
- FireWizard
Hello @aBjerris
You wrote:
that you receive a Connack (Connection Acknowledged) timeout, as the client (ZwaveJS-UI), is not able to connect.
There is no reason to reboot Mosquitto or any other MQTT server.
MQTT brokers can run continuously.
Sorry for the confusion, as I mentioned the time-out parameter, but I meant the keepalive.
The keep alive parameter has to be set by the client, but not all clients have this option available.
And ZWaveJS-UI and also Domoticz do not have this option available.
This website has a complete series of interesting articles. worthwhile to read.
But it is great that everything works, now.
Please mark the thread as "Solved".
You wrote:
It is quite obvious, that, as long as the broker (Mosquitto) has not started completely yet and so is unavailable,I started Mosqutto before I started Zwave JS UI.
Yes, there is.So, I guess there is a dependency on the start order of the services.
I recommend to read the following blog post: https://www.hivemq.com/blog/mqtt-essent ... blishment/Is there a better explanation?
