Version: 2024.7
Platform: Raspberry Pi 3B+
Plugin/Hardware: RFXtrx433E
Description: Only 1 Switch showing up
I installed Domoticz on a new Raspberry Pi and it detects my KAKU switches when I use my remotes. However, only 1 device shows up in the Switches tab. This switch works OK but whatever I do, I cannot get any other Device to show up as Switch.
My RFX433 is not on the latest firmware but this doesn't seem to be the issue to me.
Devices not showing up as Switches [SOLVED] Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.7
Re: Devices not showing up as Switches
Check your user settings in menu Setup - Users.
If you are logged in as an admin the assigned devices list for that user should be empty. Else you have to add every new device also to that assigned devices list to get it visible.
Thanks, problem solved!
