skip dzvents action at domoticz startup
Newbie
Post by Newbie »
Version: Domoticz 2024.7 (build 16325)
Platform: DietPi 9.8.0 on Odroid C4
Plugin/Hardware: Generic sysfs GPIO, MQTT Auto Discovery Client Gateway with LAN interface, Satel Integra via LAN interface, Open Weather Map, Evohome via Web API, Kodi Media Server, Dummy (Does nothing, use for virtual switches only) .
Description: Hello all.
I did a script that turns on the entrance light when my satel integra is deactivate at nighttime or my blinds are closed. Here the code:
        devices = { 'Satel INTEGRA' }
    data = {
        contatore = { initial = 0 }
        if (device.inActive and domoticz.data.contatore == 1) then
            local tapparelle = domoticz.devices('Tapparella cucina').level +
                               domoticz.devices('Tapparella sala').level +
                               domoticz.devices('Tapparella bagno SX').level +
                               domoticz.devices('Tapparella bagno DX').level +
                               domoticz.devices('Tapparella cameretta').level +
                               domoticz.devices('Tapparella camera da letto').level
            if (domoticz.time.matchesRule('at civilnighttime') or tapparelle == 0) then
                if domoticz.devices('Plafoniera corridoio').inActive then
                    domoticz.devices('Plafoniera corridoio').dimTo(100).forMin(5)
        domoticz.data.contatore = 1
My goal is to prevent the light on at domoticz start, but this doesn't work. Light is always turned on as the "contatore" variable seems ignored.
What I'm doing wrong? Is there a better way to skip the first trigger at domoticz start?
solarboy
Domoticz version: 2024.6
Re: skip dzvents action at domoticz startup
Post by solarboy »
There is a system trigger you could use documented here
https://wiki.domoticz.com/DzVents:_next ... %A6}_3.0.0
You could use it to trigger a script to turn off your light at boot time.
Domoticz version: 2025.1
Your script is triggered at a change if device 'Satel INTEGRA'.
So if that device does not change at startup your script will not run. So indeed better use the system trigger to force to run the script at startup.
Newbie
Post by Newbie »
waltervl wrote: Sunday 17 November 2024 11:12 Your script is triggered at a change if device 'Satel INTEGRA'.
Well, every time domoticz starts, i receive a telegram alert with satel integra status. If I start domoticz with the alarm system armed, the script doesn't do anithing (correct), if the system is disarmed, lights are immediately switched on, so imho the satel change is triggered on startup, but the "contatore" 0 value in the first cycle is ignored,
Isn't the use of system start to turn off lights, a race condition with my script?
You only be sure when you put some logging in the script. See if it is triggered and what it reads. Now it is only guessing.
Also apparently something else is sending you a notification, not this script. So where is this notification coming from?
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
I'm trying to activate a dz script after a restart of domoticz
    on =
        timer =
            function(domoticz)
                return
                    domoticz.time.matchesRule('at ' .. domoticz.variables('UV_Sleep').value) or
                    domoticz.time.matchesRule('at '  .. minutesBeforeSunset .. 'minutes before sunset')
                end,
          devices = {Test,},
          system = {['start'] = { 'at 14:00 - 20:00'}} ,
        customEvents = {retrigger,}
Only it does not start the script after a restart/start of Domoticz
Wgat am i doing wrong ?
