Hi all
I have recently switched to zwavejs2mqtt, its working ok after a couple of days of problems, of all kind, mostly due to myself not reading everything and doing steps in the wrong order...
But now almost everything works.
The reason to switch was a new device I bought for floor heating, the 4512757 Namron / 16 A Thermostat.
It is supposed to work as far as I understand looking in: https://devices.zwave-js.io. But the device don't appear in the control panel or domoticz. It should "pop in" automatically as the other devices, but it don't.
Am I doing something wrong here adding new devices? I tried to put the thermostat in inclusion mode too, just to see if it helped, even though it isn't necessary. But no new device.
Any suggestions appreciated.
Support for Namron Thermostat
- Domoticz version: 2024.7
Re: Support for Namron Thermostat
It should be visible in Zwave-JS-UI user interface first. If it does not show there it will not pop up in Domoticz too.
I've done reset and removed the power. It will not appear in zwavejsui.
Is it really supposed to work?
What can I do different?
https://devices.zwave-js.io/?jumpTo=0x0 ... 0x0108:0.0
There is an inclusion instruction there, did you follow it?
Then perhaps better ask it on the Zwave-JS forum. There are already some discussion about the device https://github.com/zwave-js/node-zwave- ... pen+namron
