Using Domoticz Stable 2024.7 in Docker on Debian.
With newest version of Z-Wave JS UI (and MQTT) I'm experiencing the same issue as described here: https://github.com/zwave-js/zwave-js-ui/issues/3924
When I adjust the color directly in Z-Wave JS UI, I see the device functioning perfectly. The change is also neatly transferred to Domoticz via MQTT.
When I try to adjust the color in Domoticz, nothing happens. Only level changes seems to reach Z-Wave JS UI. The color changes are not 'understood'.
Log Z-Wave JS UI:
2024-10-26 19:57:43.671 INFO STORE: Message received on zwave/24V_LED_driver/51/0/targetColor/set: '{"state":"ON"}'
2024-10-26 19:57:43.671 INFO STORE: Writing { state: 'ON' } to 17-51-0-targetColor
2024-10-26 19:57:43.671 ERROR STORE: Unable to write { state: 'ON' } on 51-0-targetColor: Color Switch: "targetColor" must be set to an object which specifies each color channel (ZW0322)
Also through the API, the color is not changing for me when I make a request with a HEX code.
<<my ip>>:<<my port>>/json.htm?type=command¶m=setcolbrightnessvalue&idx=477&hex=FF0000&brightness=100&iswhite=false
This has always worked for me!
I have also reverted zwave-js-ui to version 9.18 and immediately afterwards I could change the color in Domoticz as usual.
I am not a programmer, but I would like to help solve this issue. Please let me know what you need.
RGBW Qubino dimmer - setcolor not working
- Domoticz version: Left
Re: RGBW Qubino dimmer - setcolor not working
I got the same issue.
I got a feeling the interface has been changed
- Domoticz version: 2.2903
My Domoticz is also unable to change the color but on a Zipato E27 led bulb...
- Domoticz version: 2024.7
It seems that if from Zwave-JS-UI the color setting goes correctly the first place to look is into Domoticz.Ewout wrote: ↑Saturday 26 October 2024 21:57 Using Domoticz Stable 2024.7 in Docker on Debian.
Log Z-Wave JS UI:
To report issues with MQTT AutoDiscover that Zwave-JS-UI is using to communicate with Domoticz use the instructions on the wiki:
https://www.domoticz.com/wiki/MQTT_AD_Report_Problems
You could also compare the MQTT messages when changing color in Zwave-JS-UI with the MQTT message when changing color in Domoticz.
- Domoticz version: 2023.2
I have the same issue with the newest ZWAVE js ui and I am gone back to 9.18.1 which worked for me again. It seems to be a zwave is ui problem. I have reported thtat month ago to Zwave Js ui as a bug.
Below some details I found in the MQTT explorer. For me this is all new, so bare with me. Right now all is working fine with Zwave-JS-UI version 9.18
Below the config payload of the RGB dimmer:
Below the last succesfully rgb_state change:
After upgrade to the latest Zwave-JS-UI version - NOT WORKING SITUATION:
MQTT message when I sucessfully change the color in the node in Zwave-JS-UI:
When I try to push red color (LED strip in my bathroom) through Domoticz, this is the log in Domoticz:
But there is no new MQTT message. I think the message doesn't get understood somehow. I think I do see a new MQTT message, but it looks like a repeat of the previous state in MQTT. So this is not with the correct color.
This is the log in Zwave-JS-UI:
It looks like Domoticz tries to write the level of the dimmer twice, but not the color! Or it's get misunderstood by Zwave-JS-UI.
17-38-0 specifies the level of the dimmer
17-51-0 specifies the color
So far my knowledge. What should be my next move?
"state_topic": "zwave/24V_LED_driver/38/0/currentValue",
"command_topic": "zwave/24V_LED_driver/38/0/targetValue/set",
"on_command_type": "brightness",
"state_value_template": "{{ \"OFF\" if value_json.value == 0 else \"ON\" }}",
"brightness_value_template": "{{ value_json.value }}",
"brightness_scale": 99,
"rgb_command_template": "{{ {'red': red, 'green': green, 'blue': blue}|to_json }}",
"rgb_value_template": "{{ value_json.value.red }},{{ value_json.value.green }},{{ value_json.value.blue }}",
"rgb_state_topic": "zwave/24V_LED_driver/51/0/currentColor",
"rgb_command_topic": "zwave/24V_LED_driver/51/0/targetColor/set",
"brightness_state_topic": "zwave/24V_LED_driver/38/0/currentValue",
"brightness_command_topic": "zwave/24V_LED_driver/38/0/targetValue/set",
"availability": [
"payload_available": "true",
"payload_not_available": "false",
"topic": "zwave/24V_LED_driver/status",
"value_template": "{{'true' if value_json.value else 'false'}}"
"topic": "zwave/_CLIENTS/ZWAVE_GATEWAY-zwave-js-ui/status",
"value_template": "{{'online' if value_json.value else 'offline'}}"
"topic": "zwave/driver/status"
"availability_mode": "all",
"device": {
"identifiers": [
"zwavejs2mqtt_0xe2118c93_node17"
"manufacturer": "Qubino",
"model": "Qubino Flush RGBW Dimmer (ZMNHWD)",
"name": "24V LED driver",
"sw_version": "2.7"
"name": "24V LED driver_rgb_dimmer",
"unique_id": "zwavejs2mqtt_0xe2118c93_17-51-0-currentColor"
"time": 1731361672168,
"value": {
"warmWhite": 0,
"red": 0,
"green": 255,
"blue": 0
"nodeName": "24V LED driver",
"nodeLocation": "Berging"
"time": 1731363004256,
"value": {
"warmWhite": 0,
"red": 0,
"green": 0,
"blue": 255
2024-11-11 23:23:11.467 Z-Wave: Light/Switch/Switch (PIR badkamer)
2024-11-11 23:23:11.484 EventSystem: Event triggered: 24V LED verlichting_10
2024-11-11 23:23:11.484 Status: EventSystem: Fetching URL 127.0.0.1:8085/json.htm?type=command¶m=setcolbrightnessvalue&idx=477&hex=ff0000&brightness=100&iswhite=false after 0.2 seconds...
2024-11-11 23:23:11.484 Status: Berging UIT - Badkamer AAN - Hal UIT
2024-11-11 23:23:11.712 Status: setcolbrightnessvalue: ID: 1dd, bri: 100, color: '{m: 3, RGB: ff0000, CWWW: 0000, CT: 0}'
2024-11-11 23:23:11.920 Z-Wave: Color Switch/RGBWZ (24V LED color)
2024-11-11 23:23:11.714 INFO STORE: Message received on zwave/24V_LED_driver/38/0/targetValue/set: '99'
2024-11-11 23:23:11.715 INFO STORE: Writing 99 to 17-38-0-targetValue
2024-11-11 23:23:11.718 INFO STORE: Message received on zwave/24V_LED_driver/51/0/targetColor/set: '{"state":"ON","value":99}'
2024-11-11 23:23:11.718 INFO STORE: Writing 99 to 17-51-0-targetColor
2024-11-11 23:23:11.719 ERROR STORE: Unable to write 99 on 51-0-targetColor: Color Switch: "targetColor" must be set to an object which specifies each color channel (ZW0322)
@Ewout Have you found a solution which works?
Does anybody know if Domoticz support supported_color_modes correctly in MQTT autodiscovery?
