struggle with text in textdevice
BartSr
Domoticz version: V2024.7
Post by BartSr »
I'm struggling with a textdevice which I want to show information on two (2) lines.
command in dzVents
dz.devices(1642).updateText('line 1'..'\n line 2')
this results in:
line1 line2
but I expected
line1
line2
what's wrong?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Tukker
Domoticz version: 2023.2
Re: struggle with text in textdevice
Post by Tukker »
Change it to:
dz.devices(1642).updateText('line 1\n line 2')
or
local textSensor = dz.devices(1642)
            if textSensor then
                local text = 'line1'..
                '\n\n line2'
                textSensor.updateText(text)
Bugs bug me.
Domoticz version: 2026.3
According Dummy wiki for text sensors: you get multiple lines when adding \r\n to the string
https://www.domoticz.com/wiki/Dummy_for ... ext_sensor
BartSr
Post by BartSr »
The problem is weird.
It apprears that the text-device itself had no problem but it occurs once the same textdevice is placed on floorplan.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
RonkA
Domoticz version: 2025.1
Post by RonkA »
Don't use floorplan (not yet..) but try maybe:
dz.devices(1642).updateText('line 1<br>line 2')
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20 - Sonos
Work in progress = Life in general..
BartSr
Post by BartSr »
@Ronka
thanks for suggestion.
your solution works fine for textdevice but if it's on a floorplan it shows up as:
feels like being a bug
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Bug or perhaps intended to not have too much data on the floorplan.
BartSr
Post by BartSr »
Walter, I expect 1st: bug. I will report abot it.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Looking at this part of code in the floorplan it looks like it should work with line breaks.
https://github.com/domoticz/domoticz/bl ... s.js#L1891
        this.data = item.Data.replace(/([^>\r\n]?)(\r\n|\n\r|\r|\n)/g, '$1<br />$2');
        if (this.data.indexOf("<br />") != -1) {
            this.hasNewLine = true;
Perhaps look with source code option in a browser if you see the <br /> in html
waltervl wrote: Thursday 07 November 2024 23:23 Looking at this part of code in the floorplan it looks like it should work with line breaks.
I asked AI what this should do and it came up with the following description:
This JavaScript line uses a regular expression to replace newline characters in a string with HTML line break tags (<br />).
Here’s a breakdown of how it works:
Regular Expression: /([^>\r\n]?)(\r\n|\n\r|\r|\n)/g
- ([^>\r\n]?): This captures any character that is not > or a newline character, zero or one time.
- (\r\n|\n\r|\r|\n): This captures any of the newline sequences (\r\n, \n\r, \r, or \n).
The g flag at the end indicates a global search, meaning it will replace all occurrences in the string.
Replacement String: '$1<br />$2'
- $1: Refers to the first captured group (any character not > or a newline).
- <br />: Inserts an HTML line break.
- $2: Refers to the second captured group (the newline sequence).
In essence, this line of code ensures that every newline in the string is replaced with an HTML line break, preserving the newline characters themselves. This is useful for displaying text with line breaks in HTML.
RonkA
Post by RonkA »
Man.. this is quickly turning in to a rabbit hole..
In HTML (up to HTML 4): use <br>
In HTML 5: <br> is preferred, but <br/> and <br /> is also acceptable
In XHTML: <br /> is preferred. Can also use <br/> or <br></br>
Notes:
<br></br> is not valid in HTML 5, it will be thought of as two line breaks.
XHTML is case sensitive, HTML is not case sensitive.
For backward compatibility, some old browsers would parse XHTML as HTML and fail on <br/> but not <br />
So.. <br /> is the way?!?
BartSr
Post by BartSr »
sorry, no same result as on yr previous proposel....
commenting using mobile so can't drop screenshot
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
