MelCloud plugin
manjh
MelCloud plugin
Post by manjh »
I installed the MelCloud plugin to control my Mitsubishi Electric airconditioning.
The plugin installs OK, and I can see a number of devices reflecting the current status of the machine.
But when I try to change a setting, the Domoticz log shows:
MelCloud: MELCloud receive unknonw message with error code 500
The setting does not change in the device.
Does anyone have experience with this plugin? Any clues as to what might be wrong?
I cannot find a way to report this error in the plugin's Github entry.
Hans
FlyingDomotic
Re: MelCloud plugin
Post by FlyingDomotic »
Error code 500 means "Internal server error". Otherwise said, the remote server (here MelCloud) has a problem...
You may perhaps contact them to ensure they know there's a problem ;-)
manjh
Re: MelCloud plugin
Post by manjh »
Is anyone else using this plugin at all? Or am I the only one trying to control the Mitsubishi Electric machine from Domoticz?
Hans
FlyingDomotic
Re: MelCloud plugin
Some people don't like to much using external servers (like MelCloud) and do prefer having a direct, local control on AC, working without Internet access.
Some, including me, are connecting an ESP8266 into CN105 AC connector (https://github.com/SwiCago/HeatPump), and use Domoticz plugin (viewtopic.php?t=28365&p=295429) to control it
You'll find more details at https://chrdavis.github.io/hacking-a-mi ... mp-Part-1/
However, generally 500 errors are only temporary ones, and are often fixed by server reboot.
manjh
Re: MelCloud plugin
Post by manjh »
FlyingDomotic wrote: Thursday 31 October 2024 21:33 Some people don't like to much using external servers (like MelCloud) and do prefer having a direct, local control on AC, working without Internet access.
Do you know of any ready-made units available?
Hans
FlyingDomotic
Re: MelCloud plugin
Personally, no, but you have only to solder 4 wires to an ESP8266, and plug the connector in A/C.
Truffe13
Domoticz version: 2024.7
Re: MelCloud plugin
Post by Truffe13 »
Could you try this plugin version, which works well for me ?
https://github.com/truffe13/domoticz-python-melcloud
manjh
Re: MelCloud plugin
Post by manjh »
Truffe13 wrote: Wednesday 30 April 2025 22:41 Could you try this plugin version, which works well for me ?
Works!
How many Domticz devices are you seeing? I got 7, not sure if there are any more!
Hans
Truffe13
Re: MelCloud plugin
Post by Truffe13 »
Great
I have got 7 devices per unit : Mode, Fan, Vane Vertical, Vane Horizontal, temp, temp set point, info
JP
