OpenUrl question
ressof
Domoticz version: Latest
OpenUrl question
Post by ressof »
I writing a script to check electical prices from Nord Pool that uses this URL:
https://dataportal-api.nordpoolgroup.com/api/DayAheadPrices?date=2024-10-19&market=DayAhead&deliveryArea=SE3&currency=SEK
You can use tomorrow date in the url but the url is only valid sometime after 13:00. Is there a way to check if the URL is valid before I'm trying to open it? If I try to open url from 13:00 and its not valid I get an error message in the log that I don't want.
habahabahaba
Domoticz version: 2024.4
Re: OpenUrl question
Post by habahabahaba »
You can try smth like this (curl is needed):
 	local handler1 = io.popen('curl -s -o /dev/null -w "%{http_code}" "URL_to_check" ')
        local response1 = handler1:read('*a')
            if (response1 == "200") then  -- if OK
ressof
Post by ressof »
Thank you for your help
