Shell recharge API interface
- Domoticz version: 2024.7
Re: Shell recharge API interface
Hi Firewizzard,
Yesterday I went through the documentation to learn about the interaction between Node-Red and Domoticz. I have installed Mosquito on my Pi and added the MQTT hardware in Domoticz.
I created 3 devices in Domoticz that are connected to Node-Red: a Push On Button with what I can poll the status, a switch that can start/stop the charging and a Text device to catch the debug output from Node-Red.
The standard output from Node-Red is also used to toggle the charge switch in case charging is started/stopped in another way.
I also created a small DzVents script that gets fired every hour and toggles the charge switch if the current electricity price is above or below a certain threshold.
I'm not able to send you the Node-Red flow and the output today but will do that a.s.a.p.
Thanks for your effort.
Regards, Henry
Regards, Henry
- FireWizard
Hello @Henry,
You wrote:
I omitted the Shell Recharge Subflow, as this contains a lot of nodes. replace the three "Inject"nodes, for Start, Stop and Poll with this flow.
Sorry, I cannot send a picture or any other attachment as I receive
I suggest to connect the status information to that "Text" node.
Below the flow:
1. In the '"Split IDX" node, replace the IDX numbers for your IDX numbers. The first one for the "Poll" button, the second one for the "Start/Stop" switch.
2. Insert your own MQTT configuration.
Let me know,
You wrote:
I did the same and I created a flow, only with default Node-RED nodes, which is attached below.I created 3 devices in Domoticz that are connected to Node-Red: a Push On Button with what I can poll the status, a switch that can start/stop the charging and a Text device
Error
Sorry, the board attachment quota has been reached.
This will be created later.The standard output from Node-Red is also used to toggle the charge switch in case charging is started/stopped in another way.
I would not recommend that. Node-RED developers advise to remove the "debug" or at least to disable them, as soon your flow is running fine.Text device to catch the debug output from Node-Red.
Below the flow:
"id": "2074b068e61ad6e2",
"type": "mqtt in",
"z": "0395707f6d3c0639",
"name": "From Domoticz",
"topic": "domoticz/out",
"qos": "2",
"datatype": "auto-detect",
"broker": "914e5d6751284bd7",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 140,
"y": 620,
"wires": [
"989856c5187ad61d"
"id": "989856c5187ad61d",
"type": "switch",
"name": "Spli IDX",
"property": "payload.idx",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "7",
"vt": "num"
"t": "eq",
"v": "8",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 340,
"y": 620,
"wires": [
"799b28b3257bc554"
"b6a7c4d4e75820b8"
"id": "799b28b3257bc554",
"type": "change",
"name": "Set Poll",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": " { \"action\": \"poll\" }",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 720,
"y": 600,
"wires": [
"0d363e613357400d"
"id": "b6a7c4d4e75820b8",
"type": "switch",
"name": "Split On/Off",
"property": "payload.nvalue",
"rules": [
"t": "eq",
"v": "0",
"vt": "num"
"t": "eq",
"v": "1",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 530,
"y": 660,
"wires": [
"4aae1ea82fd7019c"
"2f4d6af897f818f1"
"id": "4aae1ea82fd7019c",
"type": "change",
"name": "Set Stop",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": " { \"action\": \"stop\" }",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 720,
"y": 640,
"wires": [
"0d363e613357400d"
"id": "2f4d6af897f818f1",
"type": "change",
"name": "Set Start",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": " { \"action\": \"start\" }",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 720,
"y": 680,
"wires": [
"0d363e613357400d"
"id": "019bb90a657ed1cc",
"type": "inject",
"name": "Setup",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "{ \"action\": \"setup\" }",
"payloadType": "json",
"x": 730,
"y": 720,
"wires": [
"0d363e613357400d"
"id": "914e5d6751284bd7",
"type": "mqtt-broker",
"name": "",
"broker": "192.168.10.51",
"port": "1883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"autoUnsubscribe": true,
"birthTopic": "",
"birthQos": "0",
"birthRetain": "false",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closeRetain": "false",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willRetain": "false",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
Last edited by FireWizard on Sunday 13 October 2024 10:55, edited 1 time in total.
Thanks for the flow, it's a great way to learn about Node-Red. I changed it a bit to prevent the Poll to be executed when it's turned off.I did the same and I created a flow, only with default Node-RED nodes, which is attached below.
I understand but the Poll doesn't give anything on the standard output, and for now it's a nice way to see what's happening. If everything is running fine I will disable the debug output.Node-RED developers advise to remove the "debug" or at least to disable them, as soon your flow is running fine.
This is the input flow
"id": "ce4eda975b3ddb38",
"type": "tab",
"label": "Flow 2",
"disabled": false,
"info": "",
"env": []
"id": "c96c382a258260dc",
"type": "mqtt in",
"z": "ce4eda975b3ddb38",
"qos": "2",
"broker": "86f0c28c.790f4",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 200,
"y": 260,
"wires": [
"3bf37797e167b703"
"id": "3bf37797e167b703",
"type": "switch",
"name": "Split IDX",
"rules": [
"t": "eq",
"v": "307",
"vt": "num"
"t": "eq",
"v": "308",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 380,
"y": 260,
"wires": [
"e9fc7cf3fbb69a0c"
"1b3d8309d457b381"
"id": "21453f97270108fa",
"type": "change",
"name": "Set Poll",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 780,
"y": 240,
"wires": [
"id": "1b3d8309d457b381",
"type": "switch",
"rules": [
"t": "eq",
"v": "0",
"vt": "num"
"t": "eq",
"v": "1",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 570,
"y": 300,
"wires": [
"9407d73946af319b"
"56fd9b28c1869043"
"id": "9407d73946af319b",
"type": "change",
"name": "Set Stop",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 780,
"y": 280,
"wires": [
"id": "56fd9b28c1869043",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 780,
"y": 320,
"wires": [
"id": "2b6b6ab4e7178487",
"type": "inject",
"name": "Setup",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 790,
"y": 360,
"wires": [
"id": "e9fc7cf3fbb69a0c",
"type": "switch",
"rules": [
"t": "eq",
"v": "1",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 570,
"y": 240,
"wires": [
"21453f97270108fa"
"id": "86f0c28c.790f4",
"name": "Domoticz",
"broker": "localhost",
"port": "1883",
"clientid": "",
"usetls": false,
"keepalive": "15",
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
"id": "16e2583208241e69",
"type": "tab",
"label": "Flow 3",
"disabled": false,
"info": "",
"env": []
"id": "1ad4e12651b84e4e",
"type": "mqtt out",
"z": "16e2583208241e69",
"name": "To Domoticz",
"topic": "domoticz/in",
"qos": "2",
"retain": "false",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"x": 650,
"y": 380,
"wires": []
"id": "0ffc55e25886addc",
"type": "switch",
"name": "Split Laden",
"property": "payload",
"rules": [
"t": "true"
"t": "false"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 250,
"y": 360,
"wires": [
"e44416ef7e979380"
"7a9ef1d5d9dbc742"
"id": "e44416ef7e979380",
"type": "change",
"name": "Set Laden aan",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"idx\":308,\"nvalue\": 1}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 440,
"y": 340,
"wires": [
"1ad4e12651b84e4e"
"id": "7a9ef1d5d9dbc742",
"type": "change",
"name": "Set Laden uit",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"idx\":308,\"nvalue\": 0}",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 430,
"y": 380,
"wires": [
"1ad4e12651b84e4e"
"id": "8edc862f95ab7351",
"type": "change",
"name": "Set Status",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{\"idx\":309,\"svalue\":payload}",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 430,
"y": 420,
"wires": [
"1ad4e12651b84e4e"
"name": "Domoticz",
"port": "1883",
"clientid": "",
"usetls": false,
"keepalive": "15",
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
active = true,
logging = {
-- level = domoticz.LOG_DEBUG, -- uncomment for development, else comment and use generic domoticz settings
marker = 'Laden'
timer = { 'at *:01' }
execute = function(dz, item)
local laden = dz.devices('Laden')
local poll = dz.devices('Poll')
local price = dz.devices('Actual Electricity Price')
local MaxElPrice = dz.variables('MaxElPrice').value
dz.notify ('Max electricity price: ' .. MaxElPrice)
local CurElPrice = price.sensorValue
dz.notify ('Current dynamic price: ' .. CurElPrice)
-- poll.switchOn()
if (item.isTimer) then
if (CurElPrice < MaxElPrice) then
laden.switchOn().checkFirst()
laden.switchOff().checkFirst()
- FireWizard
Hello @Henry,
You wrote:
I will import the flows and I will come back to you.
You wrote:
That make sense, but I didn´t know exactly wat the result is of pushing the "Poll" button.I changed it a bit to prevent the Poll to be executed when it's turned off.
I do not understand this, as your last line shows:I understand but the Poll doesn't give anything on the standard output, and for now it's a nice way to see what's happening.
You can put that in the "Text" widget.I noticed that the Poll only gave the charger status (Occupied, Available, Charging), and not if the car is connected.
Hi @FireWizzard,
Reading it back I can see it's not that clear, but from the Readme:
Outputs
The Output payload is (boolean) true if a charge is in progress, otherwise it is (boolean) false. This is also updated when polling is in progress. All other output is from Debug labelled with topics like status, poll, response, energy and error.
So this is more than debug info. For example energy:
Outputs
{"chartTotal":{"totalkWh":"137,74","totalkgCO2":"114,669","totalTime":325298,"totalSessions":13},"chart":[{"date":"01-10-2024","sessions":1,"kwh":26.53},{"date":"02-10-2024","sessions":0,"kwh":0},{"date":"03-10-2024","sessions":1,"kwh":21.32},{"date":"04-10-2024","sessions":0,"kwh":0},{"date":"05-10-2024","sessions":1,"kwh":5.86},{"date":"06-10-2024","sessions":3,"kwh":28.48},{"date":"07-10-2024","sessions":1,"kwh":21.42},{"date":"08-10-2024","sessions":1,"kwh":21.32},{"date":"09-10-2024","sessions":0,"kwh":0},{"date":"10-10-2024","sessions":5,"kwh":12.81},{"date":"11-10-2024","sessions":0,"kwh":0},{"date":"12-10-2024","sessions":0,"kwh":0}]}
- FireWizard
Hello @Henry,
I think it is clear(at least for me).
If you hoover with your mouse over the outputs of the subflow, marked "Shell "Recharge", you will see for the upper output "Output" en for the lower one, you will see "Debug". Not a very clear explanation of their functions. But that is for something later.
At the upper one, you will find true or false. Is that correct?
At the lower one, you will find the data.
Can you set the configuration of that Debug node to "complete msg object" You can read the topics as well.
Hi @FireWizzard,
Poll:
Energy:
That's correctAt the upper one, you will find true or false. Is that correct?
How do I do that? I can't seem to find it Got itCan you set the configuration of that Debug node to "complete msg object"
Poll:
{"_msgid":"042ff7462973f423","payload":"Available","evse":"07005287","topic":"poll","_event":"node:159f5a5fe4049215-bcdf7ec7fb9f8b1e"}
{"_msgid":"7be97e12f193705a","payload":{"chartTotal":{"totalkWh":"137,74","totalkgCO2":"114,669","totalTime":325298,"totalSessions":13},"chart":[{"date":"01-10-2024","sessions":1,"kwh":26.53},{"date":"02-10-2024","sessions":0,"kwh":0},{"date":"03-10-2024","sessions":1,"kwh":21.32},{"date":"04-10-2024","sessions":0,"kwh":0},{"date":"05-10-2024","sessions":1,"kwh":5.86},{"date":"06-10-2024","sessions":3,"kwh":28.48},{"date":"07-10-2024","sessions":1,"kwh":21.42},{"date":"08-10-2024","sessions":1,"kwh":21.32},{"date":"09-10-2024","sessions":0,"kwh":0},{"date":"10-10-2024","sessions":5,"kwh":12.81},{"date":"11-10-2024","sessions":0,"kwh":0},{"date":"12-10-2024","sessions":0,"kwh":0}]},"topic":"energy","_event":"node:159f5a5fe4049215-033a44c5214cb9f0"}
- FireWizard
Hi @ Henry,
As far as I understand, the second output returns "Available" in case of a topic "poll".
According to one of your previous posts, other values are "Occupied" and "Charging"
Do you know, if there are more
Because I think that is the value, you will need in your "Text" node.
In case the topic is equal to Energy the following data is available:
1. totalkWh
2. totalkgCO2
3. totalTime
4. totalSessions:
And also for each day the number of seesions for that day and the amount of kwh for that day.
What is interesting for you to show in Domoticz?
Perhaps only the amount of kWh during the day,
Let me know, what you want.
I assume the switch Start/Stop works en starts or stops the charging. The poll monitors the status and this can be used in the "Text" sensor.
1. totalkWh
2. totalkgCO2
3. totalTime
4. totalSessions:
Hi Firewizzard,
As far as I can see “Available”, “Occupied” and “Charging” are the 3 statusses returned by a poll.
The start/stops works indeed as intended.
It would be great to have this as a device in Domoticz, the other values are not that important.What is interesting for you to show in Domoticz?
- FireWizard
hello @Henry,
I wrote in response of your question:
Connect the "Switch" node, called "Split Laden" to the first output of the "Shell Recharge" subflow.
You sent me already this part, but I modified it slightly.
Connect the input of the "Function" node to the second output of the "Shell Recharge" subflow. an test.
Do not forget to reconfigure the MQTT to your values and adjust in the "Function" node at line 2 and 5 the IDX numbers to what you have configured in Domoticz,
Test it and let me know.
I looked to that issue and created the following (part) of the flow.The standard output from Node-Red is also used to toggle the charge switch in case charging is started/stopped in another way.
"id": "f4a3d3c687ac0f2d",
"type": "mqtt out",
"qos": "2",
"retain": "false",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"x": 810,
"y": 1560,
"wires": []
"id": "90d726d7dbaac2e2",
"type": "switch",
"rules": [
"t": "true"
"t": "false"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 390,
"y": 1560,
"wires": [
"b7ebf07e8d49df10"
"b77e104eee8c5a3a"
"id": "b7ebf07e8d49df10",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{ \"command\": \"udevice\", \"idx\" : 308, \"nvalue\" : 1, \"parse\": false }",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 600,
"y": 1540,
"wires": [
"f4a3d3c687ac0f2d"
"id": "b77e104eee8c5a3a",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "{ \"command\": \"udevice\", \"idx\" : 308, \"nvalue\" : 0, \"parse\": false }",
"tot": "json"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 600,
"y": 1580,
"wires": [
"f4a3d3c687ac0f2d"
"id": "2a24bccf500e2865",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "true",
"payloadType": "bool",
"x": 190,
"y": 1540,
"wires": [
"90d726d7dbaac2e2"
"id": "d7106405632a80d2",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "false",
"x": 190,
"y": 1580,
"wires": [
"90d726d7dbaac2e2"
"name": "",
"port": "1883",
"clientid": "",
"usetls": false,
"keepalive": "60",
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
I created a small flow in order to send the Status information from the polling to the "Text" sensor and also the used Energy of the last day to a "Counter" in Domoticz, which is configured as Type: Energy. I might be needed to use a "Counter Incremental". Test it.It would be great to have this as a device in Domoticz, the other values are not that important.
"id": "50c7161fdd899f7e",
"type": "comment",
"name": "Poll Data and Energy Data",
"info": "",
"x": 590,
"y": 1320,
"wires": []
"id": "9044d29f49fd6bcb",
"type": "debug",
"name": "debug 96",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 780,
"y": 1420,
"wires": []
"id": "8e9af352711ce3a7",
"type": "function",
"name": "Data to Domoticz",
"func": "if (msg.topic == \"poll\") {\n var idx = 9;\n msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 0, \"svalue\": msg.payload.payload };\n} else if (msg.topic == \"energy\") {\n var idx = 10;\n msg.payload = { \"command\": \"udevice\", \"idx\": idx, \"nvalue\": 0, \"svalue\": ((msg.payload.chart[msg.payload.chart.length - 1].kwh) * 1000).toString() };\n}\n\nreturn msg",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 570,
"y": 1360,
"wires": [
"9044d29f49fd6bcb",
"de245197690cf2fa"
"id": "de245197690cf2fa",
"type": "mqtt out",
"qos": "2",
"retain": "false",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"x": 790,
"y": 1360,
"wires": []
"name": "",
"port": "1883",
"clientid": "",
"usetls": false,
"keepalive": "60",
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
Hi @FireWizzard,
I have added your flows and it's working great. I can see the data in de Energy counter in Domoticz.
I'm going to test some things and see what the outcome is.
Thanks and I will get back soon with my findings.
Hi @FireWizzard,
The flow is running for some time now and it's working good. I've added a timer that retrieves the energy information since midnight every 5 minutes.
Only thing is that there is no good indication if the car is connected or not. I'm going to see if that can be solved as soon as I can get the Kia integration working but for that I have to update my Pi.
Thanks for your input, I got to learn a lot about MQTT and Node-RED.
This is the flow for the energy poll
"id": "ea625032ef2b7e4e",
"type": "inject",
"name": "Every 5 mins",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "300",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 460,
"y": 580,
"wires": [
"8d6c86bac34f32e5"
"id": "8d6c86bac34f32e5",
"type": "function",
"name": "Set Energy",
"func": "var now = new Date(msg.payload)\nvar midnight = now.setHours(0,0,0,0)\nmsg.payload = {\"action\": \"energy\", \"range\": {\"start\": midnight,\"end\": msg.payload}}\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 650,
"y": 580,
"wires": [
"159f5a5fe4049215"
- FireWizard
Good evening @Henry,
You wrote:
Also your KIA can be linked to Node-RED.
See: https://flows.nodered.org/node/node-red ... -bluelinky
You wrote:
Isn't that indicated by the "Status" information "Occupied"?Only thing is that there is no good indication if the car is connected or not.
Is that really necessary, to update your Pi? Or do you mean your OS on that Pi.I'm going to see if that can be solved as soon as I can get the Kia integration working but for that I have to update my Pi.
Hello @FireWizard,
The status is 'Available' even if the car is connected and not charging. If the car is charging then the status changes to 'Charging'. I'm not sure in what situation the status is set to 'Occupied'.
The Kia plugin requires Pyton 3.9 or higher so I have to manually install this or update the OS from Buster to Bullseye and/or Bookworm.FireWizard wrote: ↑Wednesday 23 October 2024 20:22 Is that really necessary, to update your Pi? Or do you mean your OS on that Pi.
That's great! I've got it running and will see were this will get me.FireWizard wrote: ↑Wednesday 23 October 2024 20:22 Also your KIA can be linked to Node-RED.
