Hi there!
I'm having some problems how Domoticz recognizes the new plugin or any changes in the directory at all.
Let's have a simple example, even if I remove the whole plugins directory, I can still see the entries at Setup/Hardware page even those are removed. Pretty much the same case if I add a new plugin there. It's not exists in the logs.
plugin.py:
* has executable flag
* has the same ownership as Domoticz
* runs fine if I run this on terminal.
What could be wrong here?
No new plugins or changes are recognized
- jvdz
- Domoticz version: 4.107
Re: No new plugins or changes are recognized
You did restart domoticz after any changes made?
- Domoticz version: 2025.1
See also the instructions on https://www.domoticz.com/wiki/Using_Pyt ... g_a_plugin which include a restart of Domoticz if plugin folder changes.
Users browsing this forum: cmisip, Google [Bot] and 1 guest
