Hi, sorry aber mein engl. ist zu schlecht.
Ich habe Domoticz auf einem Raspi3b unter Docker laufen, es funktioniert alles. Allerdings wird Domo einmal pro voller Stunde neu gestartet, es dauert dann 5-6 Minuten bis alles wieder das ist. Meine Installation:
Version: 2024.7
Build Hash: b317cfab1
Compile Date: 2024-07-13 16:59:31
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
Für eine Tipp wäre ich dankbar.
Restart every hour / Alle Stunde Neustart
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- jvdz
- Domoticz version: 4.107
Re: Restart every hour / Alle Stunde Neustart
Try anyways as this is an English forum!
- Domoticz version: 2024.1
It clearly is not normal if your domoticz restarts every hour. It is probably caused by a script or pluging that runs every hour, but without further info it is just guessing.kalle wrote: ↑Thursday 12 September 2024 9:42 Hi, sorry aber mein engl. ist zu schlecht.
Version: 2024.7
Try switching off as many scripts, plugins, hardware and devices as possible and then add them one by one, with a few hours in between. If the problem reoccurs then your last addition is probably the cause.
Another process that runs every hour is the automatic backup. Have you changed anything to it, such as the permissions on the backup folder? Try setting automatic backup to off in the settings and see whether that solves the problem.
Any error messages in the log?
Try switching off as many scripts, plugins, hardware and devices as possible and then add them one by one, with a few hours in between. If the problem occurs again, the last addition is probably the cause.
I had already tested this, without success
Another process that runs every hour is the automatic backup. Have you changed anything in it, e.g. the permissions for the backup folder? Try disabling the automatic backup in the settings to see if this fixes the problem.
This seems to be the right way to go No reboot after switching off
Are there any error messages in the log?
No entry
Thanks for the tip
Translated with DeepL.com (free version)
No entry
Thanks for the tip
- Domoticz version: 2024.7
If the automatic backup is the issue you have a database issue or disk size issue. You can start with the free disk size check. Also check the size of your database (domoticz.db). It should maximum be a 20 to 50 MB. If it is way bigger you have to investigate why it is so large.
The automatic fuse is not the problem. But it stops Domoticz every hour, that was the problem.
I make a backup once a day with a script and Raspeberry. That's ok,
It could be some translation issue but here you wrote that you disabled the automatic backup:
kalle wrote: ↑Thursday 12 September 2024 17:06 Another process that runs every hour is the automatic backup. Have you changed anything in it, e.g. the permissions for the backup folder? Try disabling the automatic backup in the settings to see if this fixes the problem.
Users browsing this forum: eddieb and 1 guest
