Sending data from JK BMS to Domoticz
manbat1980
Post by manbat1980 »
I have JK BMS from which I would like to send data to Domoticz. Please help me how to do it, maybe someone already has a solution? My model is PB2A16S20P
https://www.jkbms.com/product/jk-pb2a16 ... 2a16s-20p/
Domoticz version: 2025.1
Re: Sending data from JK BMS to Domoticz
Look at https://github.com/fl4p/batmon-ha
It seems MQTT-AutoDiscover compatible so if you have already MQTT (or even MQTT-AutoDiscover) in your environment you are quicly setup.
https://www.domoticz.com/wiki/MQTT#Add_ ... Gateway.22
gizmocuz
Post by gizmocuz »
Not exactly what you are may be looking for, but this could be used to push it to InfluxDB
https://github.com/gizmocuz/Victron/tre ... o%20Influx
This is a python script that you can run in the background
This principle you can also perform for the JK
FireWizard
Post by FireWizard »
The device supports CAN and so have a look at: https://domoticx.com/node-red-voorbeeld ... -uitlezen/
