wipe / remove devices
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
PeterRozenveld
Post by PeterRozenveld »
Why is it not possible to delete devices from the Aeon stick in Domoticz ? (When the hardware is broken or send back to the store)
Domoticz version: 2024.7
Re: wipe / remove devices
What integration? Openzwave or Zwave-JS-UI?
madpatrick
Domoticz version: 2025.1
Post by madpatrick »
PeterRozenveld wrote: Tuesday 10 September 2024 9:38 Why is it not possible to delete devices from the Aeon stick in Domoticz ? (When the hardware is broken or send back to the store)
The easiest way to my opinion is to use Z-Wave PC Controller 5 on your windows PC.
Use "Node failed" and then "remove failed node"
Worked for me everytime
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
PeterRozenveld
I will try soon, thank you!
