Extreme number of triggers from energy measurement
For devices supporting the Auto Discovery feature. Like ZWaveJS2MQTT, Zigbee2MQTT.
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
I have multiple energy measuring devices, from different manufactureres, all zigbee (MQTT, autodiscovery).
The purpose was to monitor the update frequency to determine the stability of the zigbee network.
The results got me flabbercasted, the amount of updates/triggers is INSANE.
What is happening/wrong here?
The code:
		devices = {
			'Blitzwolf 01 Koelkast energy',
			'Tuya SurroundSpeakers energy'
	logging = {},
	execute = function(dz, device, triggerInfo)
		if device.name=='Blitzwolf 01 Koelkast energy' then
		    local actual = dz.devices('Zigbee_update_koelkast').counter + 1
		    dz.devices('Zigbee_update_koelkast').updateCounter(actual)
		    do return end
		if device.name=='Tuya SurroundSpeakers energy' then
		    local actual = dz.devices('Zigbee_update_surround').counter + 1
		    dz.devices('Zigbee_update_surround').updateCounter(actual)
		    do return end
Devices monitored:
Counters after ~15minutes:
Resulting (ofcourse) in the following overflow entries:
 2024-08-11 21:50:00.607 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1684, sValue: '885443715983617949696', sUsage: '0', dType: 243, sType: 28)
2024-08-11 21:55:00.094 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1684, sValue: '14507109848176000042532864', sUsage: '0', dType: 243, sType: 28)
2024-08-11 22:00:00.628 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1684, sValue: '59421121957798200420987830272', sUsage: '0', dType: 243, sType: 28)
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe - open weather map - wol - BBQ detection - rsync backup
Domoticz version: 2024.7
Re: Extreme number of triggers from energy measurement
I never has seen
do return end
In a dzvents script. What should it do?
azonneveld
waltervl wrote: Monday 12 August 2024 0:12 I never has seen
do return end
It prevents the rest of the script from executing.
Normally used in httpresponses, not really needed in this case, but it does no harm.
I would remove them and also to be sure change one local actual into actual2 so they for sure wont use values of each other.
Users browsing this forum: MichelFrance and 1 guest
