How Configure Zigbee Device
Micha123
Post by Micha123 »
hi, i have installed this plugin
now i need to setup my dimmer switch (robb dimmer)
how i can set this parameter in this plugin for my dimmer, i have an toggle switch not en momentary button
need also to setup the dimming times, have all parameters but how send them to the device with this plugin ?
0x0D External switch
type 1
0x00 Button (Momentary buttons )
0x01 Toggle (2-state Switches )
Using the ZigbeeForDomoticz plugin
Domoticz version: 2025.1
Re: How Configure Zigbee Device
Can you link to the device? As it does not look to be a dimmer but a button device.
pipiche
Post by pipiche »
Micha123 wrote: Wednesday 07 August 2024 20:06 hi, i have installed this plugin
type 1
I understand that you are using ZigbeeforDomoticz plugin. You can probably find some help in the wiki here https://github.com/zigbeefordomoticz/wi ... /Readme.md
then the forum is also good place , but you need to provide a bit more information such as, what have been done, what are the plugin logs ....
Micha123
Post by Micha123 »
I switched to zigbee2mqtt now its working and i have all settings i need in it. Thank you.
