Zipato RGBW Bulb V2 RGBWE2 Topic is solved
splitfile
Post by splitfile »
I have just moved from Open-Zwave to Zwave JS UI. All seems to work except the colors on my Zipato RGBW Bulb V2 RGBWE2.
I can adjust the light intensity up and down, but I can't set any colors. Have tried via Zwave JS UI color picker. Domoticz color picker.
Also tried via json api:
curl -s "http://192.168.1.2:8181/json.htm?type=command&param=setcolbrightnessvalue&idx=380&hex=00FF00&brightness=100&iswhite=true"
But no colors can be seen. Any ideas?
Best regards
Domoticz version: 2024.7
Re: Zipato RGBW Bulb V2 RGBWE2
If it is not working with the Zwave-JS-UI color picker it is an issue with Zwave-JS and not in Domoticz or MQTT. So I would check the Zwave-JS-UI and Zwave-JS GitHub repository for similar issues and if nothing found there make your own Zwave-JS-UI issue so it can be solved by the Zwave-JS-UI team.
solarboy
Domoticz version: 2024.6
Post by solarboy »
I have 3 of these bulbs, I always had trouble with them and then 2 of them failed (refused to pair and constantly dropping off the network once I got them paired). The mapping of the sliders in the colour picker never seemed logical as with my other RGB bulbs also.
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),SMA Hub (docker),Harmony Hub plugin, Kodi plugin,Homebridge(docker)+Google Home,APC UPS,SMA Modbus,Mitsubishi MQTT, Broadlink,Dombus
Color change for Zipato bulbs should be fixed in 2023 https://github.com/zwave-js/node-zwave-js/pull/5993
splitfile
Post by splitfile »
For me it worked very well with Open Zwave.
Yes I saw that pull request, but it is not working for me.
I installed Zwave JS UI in July 2024 so I assume that fix is included.
I will open a new bug report at Zwave JS UI.
splitfile
Post by splitfile »
Solution:
You need to set warm white and cold white to zero (0) first. Then you can set the RGB colors.
https://github.com/zwave-js/zwave-js-ui/issues/3840
