Just a question
Dave21w
Domoticz version: Stable
Just a question
Post by Dave21w »
I know you can use the toggle command to flip a light on /off on each press of a button however is it possible to toggle it between say 50% brightness and off using blockly.
Dave
Domoticz version: 2026.3
Re: Just a question
You can perhaps do that based on dimlevel
If light = on and dimlevel= 50 then light off
If light = off then set dimlevel 50
Dave21w
Re: Just a question
Post by Dave21w »
Thanks @waltervl,
I'll give it a try, to be honest I only gave half the info as I'm also controlling the dimmer from somewhere else which is the easy part, if sensor is triggered and time is after x or before y turn on dimmer at 2% for 5 mins but then I also need to be able to turn the lamp on and off with a button at a different brightness level during the day.
