Does not work command: http://username:password@domoticz ip:port
- Domoticz version: 2024.4
hi gays
i want use command http://username:password@domoticz ip:port
but does not work and when i enter this , open login page and request username and password.
also when i want send this command :
http://username:[email protected]: ... itchcmd=On
i have answer:
401 Unauthorized
i have answer:
401 Unauthorized
- Domoticz version: 2024.7
Re: Does not work command: http://username:password@domoticz ip:port
Do you have setting "Allow Basic-Auth authentication over plain HTTP (API only)" enabled in menu setup - Settings, tab security?
Edit: also some browsers do not allow to add user:password so to test you have to use something like curl or postman.
I have also been trying to backup from a curl script with http://username:password@ipaddress/backupdatabase.php and get the same 401 Unauthorized
I have "Allow basic authorisation for HTTP" enabled in setup.
I know the username / password are good as I use them to log in
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
And that user is an admin? Else it has no right to make a backup.mark.sellwood wrote: ↑Wednesday 24 July 2024 0:22 I know the username / password are good as I use them to log in
Also if you login from an IP in the trusted network range don't give user:password.
Yes, the user is an Admin
If I add the Raspberry IP in as a Trusted Networks it works fine with no user:password
edit : i resolve it with curl. thank you
Could you please let me know the command you are using?
This is waht I gave & am getting the error/
/usr/bin/curl -k "https://user:password@IP_Address/backupdatabase.php" > /home/Mark/tmp/Backup.db
- Domoticz version: 2020.2
Are there any ":", "@" or "/" in username and/or password?
No, just standard text
It seems you're using https in curl, while using http in first message. Is this an error ?mark.sellwood wrote: ↑Wednesday 24 July 2024 8:39 Could you please let me know the command you are using?
My bad, this is what im using
/usr/bin/curl -s "http://user:password@IP_Address:8080/backupdatabase.php" > /home/Mark/tmp/Backup.db
What's exact error message?
I assume you properly checked user and password, including lower/uppercase.
In the output file I have
<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>
For backup issue also see viewtopic.php?p=315818
I found something...
I just tried the same (curl -k "http://username:password@ip:8080/backupdatabase.php" > Backup.db) with 2024.6 and 2020.2 with success.
I also tried without username and password (curl -k "http://ip:8080/backupdatabase.php" > Backup.db) and it also worked.
Both tests where done with the requesting machine in list of trusted networks in Security tab of Settings.
When removing it from list of trusted networks, I got the same error as you, with and without password (401 errors)
When trying API call (/json.htm?type=command¶m=getversion), everything ran well.
Going back to wiki (RTFM), if found at https://www.domoticz.com/wiki/Security:
As your call is not an API call (not starting with /json.htm), you're not allowed to identify this way. You should either:
Tip: carefully check that trusted networks are separated by a ";" as I had some surprises with a mistyped ","
Provide valid credentials via 'Basic-Auth' with each API request. Only accepted for API calls!
- Put machine (or subnet) into trusted network list
- As doc says: Retrieve an 'Access Token' (JWT Token) from the IAM server and provide this Bearer token with each request
Thanks for checking that our for me, I was coming to the same conclusion
ie to do a backup the User needs to be an Admin & the IP needs to be Trusted.
... or write a small script, on machine having Domoticz, to generate backup locally and copy database to remote machine.
Or just enable the built in backup mechanism with automated hourly, daily and monthly backups.
in a .py file i use this code:mark.sellwood wrote: ↑Wednesday 24 July 2024 8:39 Could you please let me know the command you are using?
import pycurl
from io import BytesIO
buffer = BytesIO()
curl = pycurl.Curl()
curl.setopt(pycurl.URL, 'http://username:[email protected]:8080/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On')
curl.setopt(pycurl.USERAGENT, "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:120.0) Gecko/20100101 Firefox/120.0")
curl.setopt(pycurl.WRITEDATA, buffer)
curl.perform()
curl.close()
Thanks for all your feedback.
I have now enabled the automated backups & once a day I copy the off to my NAS as a off line backup.
