Energy Dashboard (Build in)
imautohuttraeger
- Domoticz version: 2025.1
Re: Energy Dashboard (Build in)
[/quote]
You have to enable (Dynamic) price calculation. Select a specific sensor with dynamic price information or use the fixed "internal (meter settings)"
[/quote]
I did, but the dashboard still shows Zero. I guess I am too dull witted here ...
[/quote]
- IMG_COM_202407161744034220.jpg (86.49 KiB) Viewed 2347 times
imautohuttraeger
Dummy P1 meter shows the costs correctly.
- IMG_COM_202407161757472990.jpg (87.93 KiB) Viewed 2343 times
imautohuttraeger
OK, now it is visible. Sorry, I should have read page 2 of this post, where @waltervl already explained to another user, that it lasts a while until something is visible (and maybe strange data on the first day)
1kke
Is this stored somewhere for the history graphics?
- Screenshot at Jul 17 21-12-05.png (140.27 KiB) Viewed 2253 times
No, it is a calculated value.
1kke
Okay, thanks
- Hzuu
- Target OS: -
After updating Domoticz I am not able to select 'Internal (Meter Settings)'.
I do have a P1 Smart Meter but only 'Disabled' is selectable.
Does anybody have any idea what could be wrong here?
imautohuttraeger
Just a small one: When the dashboard is open and the browser runs in the background of your device, then the time is not updated when you bring the browser tab back to the front without manually reloading the page. However, the power and energy figures are updated. Maybe a query can be integrated that compares displayed time and system time every time a power figure changes.
- IMG_COM_202407181408370030.jpg (135.34 KiB) Viewed 2145 times
You dont seem to run the default template? Perhaps clear browser cache or run the Domoticz session in an private/incognito session.Hzuu wrote: Thursday 18 July 2024 11:07 After updating Domoticz I am not able to select 'Internal (Meter Settings)'.
rensbr
The new energy display looks very good, but is there a reason why it does not show any values when i try to reach it trough a reverse proxy (nginx proxy server)?
The dashboard works when i reach it trough the IP adres of Domoticz.
- Hzuu
- Target OS: -
Done that but doesn't make any difference.waltervl wrote: Thursday 18 July 2024 16:36You dont seem to run the default template? Perhaps clear browser cache or run the Domoticz session in an private/incognito session.Hzuu wrote: Thursday 18 July 2024 11:07 After updating Domoticz I am not able to select 'Internal (Meter Settings)'.
This is for me new, i'm just starting with home automatisering. Is it posible to make it for 2 grids? I have a SolarEdge and a Growatt. Can this in de same dashboard?
No you have to combine them in a dummy device and use that on the energy dashboard. An example script to combine 2 (or more) solar inverter can be found in this topic here https://www.domoticz.com/forum/viewtopi ... 34#p317834wizzman54 wrote: Sunday 21 July 2024 12:24 This is for me new, i'm just starting with home automatisering. Is it posible to make it for 2 grids? I have a SolarEdge and a Growatt. Can this in de same dashboard?
ChriWo
- Domoticz version: 2022.1
I have a P1 and I also get the values in from a IR reading head for Use and Return see picture.
What I not geht ist the calculated watt I can see this value in the device Log but I don't see this value in the Energy Dashboard
Is this normal? What am I doing wrong? Where can I find this value? Can I write a skript?
Thank for the help
Thank for the help
- Bildschirmfoto 2024-07-22 um 19.29.08.png (273.38 KiB) Viewed 1850 times
- Bildschirmfoto 2024-07-22 um 18.49.45.png (116.35 KiB) Viewed 1850 times
- Bildschirmfoto 2024-07-22 um 18.50.08.png (60.76 KiB) Viewed 1850 times
imautohuttraeger
Do you mean 2.4 Watt return that you can see in the log? The screenshot of the log seems to be 40 minutes older than the one of the dashboard ... or am I misunderstanding something here?
How do you get the IR reading into the P1 device? Script? Python Plugin? Is there already a device in Domoticz showing the actual watt?
ChriWo
I'm having a script here you see the updating of the P1 virtual:
local Bezug_W = math.floor(sValue_Bezug_W,0)
local Einspeisung_W = math.floor(sValue_Einspeisung_W,0)
dz.devices('P1 Virtual').updateP1(Bezug_W,0,Einspeisung_W,0,0,0)
I only have this to values, but the P1 is calculating the actuals see picture so how to get this values ?
In this example you have 6.600 Watt this is 6.6 KW if I'm not mistaken.
best regards
best regards
- Bildschirmfoto 2024-07-22 um 21.15.08.png (108.29 KiB) Viewed 1826 times
Dzvents:
updateP1(usage1, usage2, return1, return2, cons, prod)
where
USAGE1= integer, total cumulative energy usage meter tariff 1 in Wh.
USAGE2= integer, total cumulative energy usage meter tariff 2 in Wh.
RETURN1= integer, total cumulative energy return meter tariff 1 in Wh.
RETURN2= integer, total cumulative energy return meter tariff 2 in Wh.
CONS= actual usage power (Watt)
PROD= actual return power (Watt)
You seem to have mixed up Power (Watt) and Energy (Wh).
where
ChriWo
No I'm having no USAGE1 at the moment I get all energy out of the battery. So I only have a RETURN1 value for today of 19.220 kW (like in the picture P1 virtual) and a total of the counter 68014.160 kW. and this is ok and the P1 is using this value.
I like to know where are the values for example 6600 W are stored this values are calculated by the P1 device.
Thanks for the help
Thanks for the help
No, Power (watt) is never a calculated value in a Domoticz device. A proper P1 device (smart meter) will send this value to Domoticz.
So in the picture all the Watt values from actual devices (Solar, Battery and P1) are being read from the Domoticz devices. In the dashboard the Home Watt values and the Watt values on the connection lines are calculated.
So as your P1 Virtual Widget shows 0 Watt the dashboard will also show 0 Watt.
