P1 meter log display
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
yann500
Post by yann500 »
After updated my domoticz, I've seen that log display for P1 counter has changed. In usage last month graphic, I had usage 1 and usage 2 and now I have only total usage. Is it possible to change it?
Thanks in advance.
Yann
janpep
Domoticz version: 2025.1
Re: P1 meter log display
Post by janpep »
Indeed. I liked it also with both slightly different colors on top of each other. And it would be nice if that was possible for all these bars.
Dz on Ubuntu VM on DS718+ behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
yann500
Post by yann500 »
I would like to find this display.
gizmocuz
Post by gizmocuz »
I find this view a way easier for the eyes:
Why do you always need to see the difference between T1/T2, by now you should know what your nightly usage is.
You can still see this when you go to the report view
Isn't it way more interesting to quickly see the actual usage?
janpep
Post by janpep »
gizmocuz wrote: Thursday 08 August 2024 17:34 .... , by now you should know what your nightly usage is.
This is a very strange argument. Then you can also say: "Skip the daily usage because by now you should know what your daily usage is. And we will also plan to skip the yearly usage. You should know by now."
Fact is that some people liked it the way it was. Their reason may vary and is actually unimportant.
Is it an idea to make it configurable in the settings?
Advantage that you can see the day and night rate ratio and the day to day difference at a glance.
Although less important, in the annual overview would it also be very nice to see how this ratio changes over the years. At a certain percentage it can become unattractive to have two counters. Now I calculate that from the annual overview of my energy company.
PS. I do not have solar panels. So no return.
PierreT
Post by PierreT »
Seems to have been intended differently as settings allows you to choose between dual tariff and dynamic tariff. This setting does in fact work on the report page where it will show the two different shades of blue (and green if also delivering), however on the normal log page the week graph was removed completely and replaced with the dynamic pricing view which is essentially a bar graph copy of the last X days graph directly above it.
gizmocuz
Post by gizmocuz »
Correct, and there is a little button you can press '1w' to display just a week
This to be more consistent with the other graph overviews
