Enphase plugin error
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2021.1
After enphase update the domoticz enphase plugin doesnt work any more.
Is there a fix for this?
- Domoticz version: 2024.7
Re: Enphase plugin error
What Enphase plugin? A Python plugin or the build in integration?
To what firmware version your enphase updated?
Also check this wiki for the build in integration. https://www.domoticz.com/wiki/Enphase
Thanks for your reply
Plugin is :
H4nsy enphase envoy plugin (python)
Version of my envoy s metered : d8.2.4225
Plugin is :
Then you either switch to the build in Enphase integration or contact the plugin author on github to see if he knows a solution.
Thanks for your help,
Do you know if the build in plugin uses the same devices ? Or do i have to delete them and loose all off my historical data
I believe there is only an issue with the P1 device the plugin is using to see the usage.
The built in integration uses the normal kWh Electricity device.
See also https://www.domoticz.com/forum/viewtopic.php?t=31959 and https://www.domoticz.com/forum/viewtopic.php?t=41093
Built in plugin does not work anymore also since update.
2024-07-11 11:12:15.252 Error: Enphase: Error getting http data! (production)
Is there a fix for that?
I also have a problem. Using newest Domoticz build 16150, Metered Envoy firmware 7.6.175, built in Enphase integration. Domoticz forgot my username/password for Enlighten, but now it has been configured correctly (credentials tested on Enlighten site) but still doesn't work. Domoticz does not show values for the meters and log file has many of the following error messages:
2024-07-11 12:25:38.530 Error: Enphase: Invalid data received! (no session_id)
Better react in the integration topic, there are also instructions there.
https://www.domoticz.com/forum/viewtopi ... &start=140
Users browsing this forum: Varazir and 1 guest
