Monit (mail)alerts not working
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Raspberry Pi 3B+ BullsEye build 1725 Monit 5.27.2
Installed and configured monit according wiki page https://www.domoticz.com/wiki/Monitoring_domoticz.
# My mail server configuration on /etc/monit/monitrc
    set mailserver smtp.telfortglasvezel.nl port 587
    username "[email protected]" password "PASSWORD"
    using AUTO
    with timeout 30 seconds
    set alert [email protected]
When this script is active monit sends the following error
[2024-07-03T13:15:00+0200] info     : 'mcmellow-pi' Monit 5.27.2 started
[2024-07-03T13:15:01+0200] error    : Mail: Mailserver response error -- 501 5.1.7 Bad sender address syntax
[2024-07-03T13:15:01+0200] info     : Adding event to the queue file /var/lib/monit/events/1720005301_55745a71c0 for later delivery
[2024-07-03T13:15:01+0200] error    : Alert handler failed, retry scheduled for next cycle
The configuration uses the same things as used for Domoticz sending notifications by email. That works OK.
Is there something I overlooked or is wrong?
Greetings McMelloW
Kedi
Domoticz version: latest
Re: Monit (mail)alerts not working
Post by Kedi »
Is mail outside Domoticz, like with bash, working?
Because Domoticz has his own smtpclient for sending mail, Monit does not, it uses the system mailclient afaik.
McMelloW
Post by McMelloW »
Kedi wrote: Wednesday 03 July 2024 14:27 Is mail outside Domoticz, like with bash, working?
Which smtpclient can I use to send mail from a Raspberry Pi
Greetings McMelloW
Kedi
Post by Kedi »
I use a simple email client -> msmtp
McMelloW
Post by McMelloW »
Kedi wrote: Wednesday 03 July 2024 19:27 I use a simple email client -> msmtp
Thanks, I installed the same and after the first commandline test I received the following errors. Shoot me.
echo -e "Subject: Test Mail\r\n\r\nThis is a test mail" |msmtp --debug --from=default -t  [email protected]
<-- 501 5.1.7 Bad sender address syntax
msmtp: envelope from address default not accepted by the server
msmtp: server message: 501 5.1.7 Bad sender address syntax
msmtp: could not send mail (account default from /etc/msmtprc)
Greetings McMelloW
Kedi
Post by Kedi »
So what's the content of /etc/msmtprc or (what I use) .msmtprc in the home directory.
/etc/msmtprc is the global setting in the home dir is the user setting.
Read the doc. https://marlam.de/msmtp/documentation/
B.t.w. I looked a little bit further in my system (it was a long time ago I configured monit)
It looks now to me that monit can mail internally. https://mmonit.com/monit/documentation/ ... t-delivery
McMelloW
Post by McMelloW »
Kedi wrote: Wednesday 03 July 2024 21:10 B.t.w. I looked a little bit further in my system (it was a long time ago I configured monit)
That is the way it is also explained in the Domoticz wiki. See my first posting.
Greetings McMelloW
Kedi
Post by Kedi »
Sorry for hasty en not good reaing of your post.
B.t.b. msmtp can help when emailing via bash...
Your error is Bad sender address syntax
I use from: $HOST@<dominename>
Fill your domain instead of the <dominename>
This my setting.
set mail-format {
  subject: $SERVICE $EVENT at $DATE
  message: $EVENT Service $SERVICE
                Date:        $DATE
                Action:      $ACTION
                Host:        $HOST
                Description: $DESCRIPTION
           Your faithful employee,
           Monit }
McMelloW
Post by McMelloW »
Kedi wrote: Wednesday 03 July 2024 22:35 Sorry for hasty en not good reaing of your post.
This my setting.
set mail-format {
                Date:        $DATE
                Action:      $ACTION
                Host:        $HOST
           Monit }
What did you used as mailserver configuration in your monitrc
Greetings McMelloW
Domoticz version: 2026.3
Just a workaround: I use Domoticz own notify functions to notify me when Domoticz has been (re)started with the following dzvents script . https://www.domoticz.com/forum/viewtopic.php?t=25209
Kedi
Post by Kedi »
You can't use Domoticz notification system if Domoticz is somehow not responding anymore.
My server setting is:
set mailserver smtp.ziggo.nl port 587 username <emailname>@ziggo.nl password '<password>' using SSL with timeout 30 seconds
I have my password between single quotes.
If Domoticz server is not responding it will be restarted by monit and Domoticz will send the notification.
McMelloW
Post by McMelloW »
waltervl wrote: Thursday 04 July 2024 16:26 If Domoticz server is not responding it will be restarted by monit and Domoticz will send the notification.
Thanks for your reply.
Yes, that is working OK. Domoticz does send a notification when restarted. But I do monitor others running services as well with Monit Therefor I will have the Monit mailserver up and running.
Greetings McMelloW
Kedi
Post by Kedi »
@waltervl Your right. But then you get an email every time Domoticz is (re)started and there is no notification about the cause.
With Monit you can, and even monitor other processes on the same way.
That is why I use Monit, because Domoticz by default does not monitor my tmpfs /var/log and other processes that are in my case vital to Domoticz like Mosquitto and Node-Red and Zigbee2MQTT.
Understood. It was just a workaround for Monit email notification for Domoticz. Currently my system is very stable so no need to know why..... ;-)
McMelloW
Post by McMelloW »
Thanks for all the input, back to my first post.
Does anybody have a hint to get sending mail from monit mail server working?
Greetings McMelloW
jvdz
Domoticz version: 4.107
Post by jvdz »
Try something like this as it seems your sender address is wrong:
set mail-format {
   message: Monit $ACTION $SERVICE at $DATE on $HOST: $DESCRIPTION.
			Yours sincerely,
            monit
using AUTO
