Code to setup the connection:
protocol = "MQTTS" if self.port == "8883" else "MQTT"
self.mqttConn = Domoticz.Connection(Name=(protocol + " to " + self.address), Transport="TCP/IP", Protocol=protocol, Address=self. Address, Port=self. Port)
self.mqttConn.Connect()
Domoticz.Debug("onConnect called: Connection '"+str(Connection)+"', Status: '"+str(Status)+"', Description: '"+Description+"'")
2024-06-25 11:40:29.485 fan slaapkamer: onConnect called: Connection 'Name: '192.168.86.23', Transport: 'TCP/IP', Protocol: 'MQTT', Address: '192.168.86.23', Port: '1883', Baud: -1, Timeout: 0, Bytes: 0, Connected: False, Last Seen: 1970-01-01 01:00:00, Parent: 'None'', Status: '111', Description: 'Connection refused'
Obviously I checked: the address is reachable from the Pi. Nothing changed on the MQTT server side.
Did anything change on the implementation of the Connection object?
