Domoticz 16083 freezing (including 16086 version)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
PA3FAT
Post by PA3FAT »
Just did update to latest beta using the Domoticz interface.
Notice afterwards the system seems to freeze.
Did ./updatebeta to get it back via command line.
Same issue. Get homepage but after this it freezes.
What to check/where what is causing this?
On Pi/Latest Bullseye (did update/upgrade last week).
PA3FAT
Re: Domoticz 16083 freezing
Post by PA3FAT »
Seems (as far as i can detect now) that connecting via the browser (edge/firefox incl mobile version) the system stops.
tail - f /var/log/domoticz.log then stops showing any more messages.
PA3FAT
Re: Domoticz 16083 freezing (including 16086 version)
Post by PA3FAT »
Still in 16087 same happens
Domoticz version: 2024.7
There are some changes on the browser server communications.
What of you try a browser in private/incognito mode? If that does not stop the server you have to erase all your browser cache.
PA3FAT
Post by PA3FAT »
Cleared the Edge cache as i am not using this frequently.
Domoticz still freezes.
All other browsers e.g. FF where not active at that time. Also did not use the FF on the mobile.
PA3FAT
Post by PA3FAT »
Cleared all options again in Edge.
As soon as i start Edge it freezes.
Dave21w
Domoticz version: Stable
Post by Dave21w »
Updated my test system to 16087 just after 2pm, no issues so far.
PA3FAT
Post by PA3FAT »
On 16088 and only using Edge on laptop (no specific mode, no idea how to either) to test. Still Freezes.
PA3FAT
Post by PA3FAT »
Still my issues continue.
Just cleared Edge again with the options i can find in settings.
Still Domoticz comes to halt and GUI freezes
Please your help.
No crash log?
Did you check the troubleshooting wiki page?
PA3FAT
Post by PA3FAT »
some part of the log "var/log/domoticz.log" when i login to the GUI via user/password and directly domoticz stops working
2024-06-20 09:49:32.109 [72b18200] Debug: [web:22099] Did not find suitable Authorization!
2024-06-20 09:49:32.110 [72b18200] Debug: Web ACLF: 77.171.240.228 - - [20/Jun/2024:09:49:32.107 +0200] "GET /json HTTP/1.1" 401 91 - "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36 Edg/126.0.0.0"
2024-06-20 09:49:32.926 [72b18200] Debug: [web:22099] Host:77.171.240.228 Uri:/json.htm?type=command&param=logincheck
2024-06-20 09:49:32.927 [72b18200] Debug: [web:22099] Request Headers:
Host: www.pa3fat.nl
Connection: keep-alive
Content-Length: 375
Accept: application/json, text/plain, */*
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36 Edg/126.0.0.0
Content-Type: multipart/form-data; boundary=----WebKitFormBoundaryAJho1ohj2pNBGGEc
Origin: http://www.pa3fat.nl
Referer: http://www.pa3fat.nl/
Accept-Encoding: gzip, deflate
Accept-Language: nl,en;q=0.9,en-GB;q=0.8,en-US;q=0.7,es;q=0.6
2024-06-20 09:49:34.415 [72b18200] Debug: Web ACLF: 77.171.240.228 - - [20/Jun/2024:09:49:34.413 +0200] "GET /json HTTP/1.1" 101 0 - "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36 Edg/126.0.0.0"
2024-06-20 09:49:34.420 [72b18200] Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command&param=getdevices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=0
2024-06-20 09:49:34.468 [72b18200] Debug: CWebServer::GetJSonPage :getdevices :/json.htm?type=command&param=getdevices&filter=all&used=true&favorite=1&order=[Order]&plan=0&lastupdate=1718869774
2024-06-20 09:49:38.160 [6f5fe200] Debug: SQLH UpdateValueInt Power Kwh HwID:5 DevID:1 Type:250 sType:1 nValue:0 sValue:20105326;9887179;8176050;19918860;0;990
2024-06-20 09:49:38.169 [6f5fe200] subtype = P1 Smart Meter Power
powerusage1 = 20105.326 kWh
powerusage2 = 9887.179 kWh
powerdeliv1 = 8176.050 kWh
powerdeliv2 = 19918.859 kWh
current usage = 000 Watt
current deliv = 990 Watt
2024-06-20 09:49:38.178 [6f5fe200] P1 Smart Meter USB: P1 Smart Meter (Power Kwh)
PA3FAT
Post by PA3FAT »
all has been working for years until latest changes in Domoticz starting from 16083.
So how to find out what is causing what?????
PA3FAT
Post by PA3FAT »
how to revert to much older database ?
PA3FAT
Post by PA3FAT »
just tried with fresh installed Chrome browser on the laptop. Same issue
PA3FAT
Post by PA3FAT »
when i start domiticz like this:
sudo ./domoticz -nowwwpwd
it keeps running and can access the domoticz GUI
however when i do it like this:
sudo service domoticz.sh start
the issue restarts and domoticz is crashing
What to do???
PA3FAT wrote: Thursday 20 June 2024 11:33 how to revert to much older database ?
See https://www.domoticz.com/wiki/Raspberry ... ect_update
But what do you mean with much older? How much older?
PA3FAT
Post by PA3FAT »
Hi Walter,
Can you please check on the different methods of running domoticz. In my previous posting. As when i run without password enforcement to login it keeps running when i connect via the GUI.
I cant help you on this. I personally do not have this issue. So something is wrong on your system. I have no clue what could be the reason.
But it looks like you are running your wnw domain. So better check that configuration, but that is completely out of my knowledge zone.
So what if you connect to the Domoticz server from internal network IP address and not through your domain?
PA3FAT
Post by PA3FAT »
Will check using the internal ip and if i can run the GUI.
But i followed the troubleshooting pages and did all the manual startup actions and it keeps running.
As soon as is do sudo service domoticz start it fails.
Will keep you updated.
PA3FAT
Post by PA3FAT »
did the database check as described here
https://www.domoticz.com/wiki/Troublesh ... r_database
no errors reported.
tried via my internal ip (.40) to start the GUI.
as soon as i trigger the gui domoticz stops
what more can i do?
