I have a Pi3B+ newly set up (as the old zero was no longer supported by domoticz) connected to a P1 Meter and connected as slave to the master domoticz (running on Windows). All P1 device show up on the Pi3B=+ (in "devices" and "utilities") and are showing up in "devices" on the master domoticz. However, none of the devices show up on the "utilities" tab on the master domoticz. This used to work OK with the old version on the zero (do not know the version).
Both slave and master running domoticz 2024.4 . Did all the usual stuff (allow new device, refresh, reboot, update, etc etc.)
Does anyone have any suggestions?
Rgds, R
P1 device not in Utility tab on master domoticz
ronalddevos
- Domoticz version: 2025.1
- gizmocuz
Re: P1 device not in Utility tab on master domoticz
Okey, to recap, they show up under 'devices' in the master Domoticz, so communication between the two is working.
It's not showing up under 'Utilities'
Two things to check:
- From the devices tab, you have added them to the system? (arrow should be blue)
- If above is true, goto Settings->Users, did you specify any devices for the user you are logging in with? If yes, did you also add the P1 meter?
ronalddevos
- From the devices tab, you have added them to the system? (arrow should be blue) - Yes
- Users, did you specify any devices for the user you are logging in with? If yes, did you also add the P1 meter? - No, but I did now and they are there!
- gizmocuz
@ronalddevos , if you did not specify any devices for this user, it should see all devices.
So, I can assume you did specify 'some' devices before?
If not, could you replicate the issue by creating another user, what user-rights did you assign to the user?
