control tasmota RGB GU10 bulb from wall switch
BurningTyre
Domoticz version: 2025.1
Post by BurningTyre »
I have a Tasmota GU10 RGBCW led bulb. (https://www.athom.tech/blank-1/gu10-rgbcw)
It works perfectly with Domoticz, i can control the colors and turn it on/off.
But i want to control the colors from a wall switch. Is there any way to have a wall switch communicate with the bulb or to domoticz?
PierreT
Re: control tasmota RGB GU10 bulb from wall switch
Post by PierreT »
Sure. You can use e.g. a Klik-Aan-Klik-Uit transmitter to control a dummy device in Domoticz and then use on (dummy) device change scripting to send commands to the Tasmota device.
BurningTyre
Is a wall panel like this compatible with Domoticz?
https://ledworld.nl/sunricher-led-contr ... aneel-rgb/
BurningTyre
Or something like this, but then for EU wall socket
https://youtu.be/GERPRWChSQw?si=ten1UbeDbFnZx0-W
PierreT
Post by PierreT »
Depends on the protocol it uses. It's not listed as a supported device by RFXCOM
I was thinking less fancy. Like a klik-aan-klik-uit wall mount switch and then program Domoticz to respond to signals as follows:
  • click top for on, bottom for off
  • hold top for increase brightness/colour, hold bottom for decrease
  • if on, click top for toggle mode between brightness and colour
Users browsing this forum: eddieb, Google [Bot], imautohuttraeger, willemd and 1 guest
