SoilMoisture, Translation
This subforum contains projects posted on other sites. If you have a nice site with nice home automation projects, feel free to post it here.
Toulon7559
Domoticz version: mixed
Post by Toulon7559 »
According to the API/JSON-definition of Domoticz, soilmoisture is expressed as cbar
Soil Moisture
/json.htm?type=command&param=udevice&idx=IDX&nvalue=MOISTURE
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
MOISTURE = moisture content in cb 0-200 where:
00 - 09 = saturated, 10 - 19 = adequately wet, 20 - 59 = irrigation advice, 60 - 99 = irrigation, 100-200 = Dangerously dry,
Some available sensors do not output solimoisture as cbar, but as % (or something comparable).
Considering the background charaterictics a correct translation is non-linear and dependent on the soil-type.
Probably a specific lookup-table will be appropriate.
For a very rough & simple approximation the following scaling might be suitable,
reversely related to the API-scaling towards a scale of 0 => 100 = Dry = Wet?
Saturated = 100 ~ 96 => cb 00 ~ 09
Adequately Wet = 95 ~ 91 => cb 10 ~ 19
Irrigation advice = 90 ~ 80 => cb 20 ~ 59
Irrigation = 79 ~ 49 => cb 60 ~ 99
Very Dry = 50 ~ 0 => cb 100 ~ 200
Your opinion?
FireWizard
Re: SoilMoisture, Translation
Post by FireWizard »
Some Info, that might be of interest:
https://eos.com/blog/soil-moisture/
and
https://cosmos.ceh.ac.uk/measuring
Domoticz version: 2024.7
Centibar is related to a specific soil moisture measuring device.
If you have a measuring device that gives a 1-100 value you will have to look at the manual of that device to see what the manufacturer considers the threshold for irrigation. It could be anything.
FireWizard
Hi @waltervl
Sorry to say, that is wrong.
A centibar (cbar) is equal to 1/100 bar.
See for definitions: https://en.wikipedia.org/wiki/Bar_(unit) and https://en.wiktionary.org/wiki/centibar
So cbar is not related to a specific device, but of course there exist devices that give a result, expressed in cbar, while other do the same, but expressed in kPa (or Pa) or even something else, like percent.
I agree, that if it is expressed in a scale from 1-100 the manufacture should present a kind of conversion table.
I agree, I was not complete. I should have written: Measuring soil moisture in unit of measure centibar (or equivalent pressure uom) is related to a specific type of soil moisture measuring device.
Toulon7559
exactly is the 'problem' why a general translation is difficult.
My proposal for a very coarse translation also biased by the (usual lack of) knowledge which type of soil is measured.
It does not make sense to try to be accurate if the basic data is 'weak':
aiming for an indicative value is best achievable result .......
As said before check the manual of you sensor device that gives a percentage value. There is no general rule to create a conversion.
What measuring device are you using that gives these 0-100% values?
Toulon7559
My Ecowitt WH51 soilmoistsensor has output as %
Input for the functionality is measured AD-value.
Simple 2-point 'calibration' described in the manual is:
- take bone-dry environment and adjust related AD-value as lower reference
- put sensor in glass of water and adjust related AD-value as high reference.
In my opinion hardly has relation to real, non-linear soilmoist characteristics.
In this perspective perhaps also not worthwhile to spend effort for a translation (except as 'technical challenge') ..........
