Device added to Hardware, but not to Devices
jeremiebe
Post by jeremiebe »
I have been using Domoticz for around 7 years on Raspberry Pi. So far, everything was working properly.
This week, I have upgraded to last (2024.4) version. The upgrade worked well, most of my devices work, but not my 5 Danfoss living connect z-wave thermostat. They don't comunicate, in both sides, with Domoticz.
To fix this, I have tried to exlcude / include one, and also remove it from devices.
The exclusion / inclusion work. I can see the device under the Hardware tab.
But the device don't show in the Devices list. Hence, I cannot use it.
I haven't use Domoticz for a while, so I'm not sure. In my memories, the devices is automatically added to the Devices liste when detected by the hardware.
What can I try to fix this?
Thanks for your help.
Jérémie
Domoticz version: 2025.1
Re: Device added to Hardware, but not to Devices
You should report the issue that OpenZwave thermostats are not being supported in latest Domoticz on the GitHub repository as an issue. Only chances are slim it will be repaired as Domoticz is moving away from OpenZwave as that project stopped being maintained. You should move to Zwave-JS-UI (and MQTT).
See wiki https://www.domoticz.com/wiki/Zwave-JS-UI
gizmocuz
Post by gizmocuz »
Just making sure... accept new devices in enabled in the settings?
jeremiebe
Post by jeremiebe »
waltervl, thanks a lot.
Now I understand the problem :) I will see what I decide to fix it
gizmocuz : yes, accept new devices in enabled in the settings
Users browsing this forum: eddieb and 1 guest
