Hello support,
I have a problem that a Scene doesn't trigger all lights unfortunately. When the scene gets triggered (via a double click of a switch or via the Domoticz app), just some of the lights are turning on or off (depending of which Scene is triggered). The lights that will be triggered is very random.
First I had Domoticz running on an i7 computer with an Aeotec Z-stick. This problem occurred from the beginning. Now I’m running Domoticz on a raspberry Pi 5, but the problem remains.
All the lights are in a range of 4 meters from the Aeotec Z-stick. I also added an Aeotec Z-Wave Range Extender just to make sure.
Does anybody have encountered this issue before and are there any solutions? Thanks in advance for the reactions.
I’m running Domoticz version 2024.4 with Build Hash: 731719420
- Domoticz version: 2025.1
Re: Scene doesn't trigger all lights
You should get switch messages for all devices in the Domoticz Log (menu setup - Log) when you enable this scene. Do you see those?
You mention Zwave, do you use the old deprecated OpenZwave integration or the new Zwave-JS-UI with MQTT? if latest you could also check in Zwave-JS-UI and MQTT Explorer if all devices get their switch commands.
Bauke
Thanks for your reply. I make use of the Aeotec Z-stick 5+ USB stick.
Underneath you will find the log:. I looks like all of them are activated..
2024-04-10 13:34:35.548 Activating Scene/Group: [UIT Lampen woonkamer keuken]
2024-04-10 13:34:35.548 Activating Scene/Group Device: Koof Keuken (Off)
2024-04-10 13:34:35.548 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 2 (0x02)
2024-04-10 13:34:35.549 Z-Wave USB adapter: Usage (Unknown)
2024-04-10 13:34:35.551 Z-Wave USB adapter: General/kWh (kWh Koof Keuken)
2024-04-10 13:34:35.555 Z-Wave USB adapter: Light/Switch (Koof Keuken)
2024-04-10 13:34:35.607 Activating Scene/Group Device: Touwlamp (Off)
2024-04-10 13:34:35.607 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 35 (0x23)
2024-04-10 13:34:35.609 Z-Wave USB adapter: Light/Switch (Touwlamp)
2024-04-10 13:34:35.660 Activating Scene/Group Device: Keukenspot (Off)
2024-04-10 13:34:35.661 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 3 (0x03)
2024-04-10 13:34:35.662 Z-Wave USB adapter: Usage (Unknown)
2024-04-10 13:34:35.665 Z-Wave USB adapter: General/kWh (kWh Keukenspot)
2024-04-10 13:34:35.669 Z-Wave USB adapter: Light/Switch (Keukenspot)
2024-04-10 13:34:35.722 Activating Scene/Group Device: Staande lamp woonkamer (Off)
2024-04-10 13:34:35.723 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 36 (0x24)
2024-04-10 13:34:35.724 Z-Wave USB adapter: Light/Switch (Staande lamp woonkamer)
2024-04-10 13:34:35.775 Activating Scene/Group Device: Lichtbolletjes (Off)
2024-04-10 13:34:35.775 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 37 (0x25)
2024-04-10 13:34:35.777 Z-Wave USB adapter: Light/Switch (Lichtbolletjes)
2024-04-10 13:34:35.828 Activating Scene/Group Device: Aanrecht (Off)
2024-04-10 13:34:35.828 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 5 (0x05)
2024-04-10 13:34:35.828 Z-Wave USB adapter: Usage (Unknown)
2024-04-10 13:34:35.830 Z-Wave USB adapter: General/kWh (kWh Aanrecht)
2024-04-10 13:34:35.833 Z-Wave USB adapter: Light/Switch (Aanrecht)
2024-04-10 13:34:35.884 Activating Scene/Group Device: Lampen op TV dressoir (Off)
2024-04-10 13:34:35.884 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 38 (0x26)
2024-04-10 13:34:35.886 Z-Wave USB adapter: Light/Switch (Lampen op TV dressoir)
2024-04-10 13:34:35.937 Activating Scene/Group Device: Eettafel (Off)
2024-04-10 13:34:35.937 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 4 (0x04)
2024-04-10 13:34:35.937 Z-Wave USB adapter: Usage (Unknown)
2024-04-10 13:34:35.939 Z-Wave USB adapter: General/kWh (kWh Eettafel)
2024-04-10 13:34:35.941 Z-Wave USB adapter: Light/Switch (Eettafel)
2024-04-10 13:34:35.992 Activating Scene/Group Device: Achterkamer (Off)
2024-04-10 13:34:35.992 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 6 (0x06)
2024-04-10 13:34:35.993 Z-Wave USB adapter: Usage (Unknown)
2024-04-10 13:34:35.994 Z-Wave USB adapter: General/kWh (kWh Achterkamer)
2024-04-10 13:34:35.999 Z-Wave USB adapter: Light/Switch (Achterkamer)
2024-04-10 13:34:35.547 Status: User: admin (IP: 168.163.215.14) initiated a scene/group command
2024-04-10 13:34:36.050 Activating Scene/Group Device: Woonkamertafel (Off)
2024-04-10 13:34:36.050 Z-Wave USB adapter: Domoticz has send a Switch command!, Level: 0, NodeID: 7 (0x07)
2024-04-10 13:34:36.051 Z-Wave USB adapter: Usage (Unknown)
2024-04-10 13:34:36.052 Z-Wave USB adapter: General/kWh (kWh Woonkamertafel)
2024-04-10 13:34:36.054 Z-Wave USB adapter: Light/Switch (Woonkamertafel)
2024-04-10 13:34:42.218 Status: Z-Wave USB adapter: Received timeout notification from HomeID: 3859117696, NodeID: 6 (0x06)
2024-04-10 13:34:50.748 Z-Wave USB adapter: Usage (Vermogen Studio)
2024-04-10 13:34:50.750 Z-Wave USB adapter: General/kWh (kWh Studio)
2024-04-10 13:34:58.687 Z-Wave USB adapter: General/kWh (kWh Hal)
2024-04-10 13:35:26.519 Honeywell Verwarming: Fetch data from server
2024-04-10 13:35:30.708 Z-Wave USB adapter: General/kWh (kWh Overloop)
Then it seems a Zwave issue then. These commands do not always reach the nodes. It looks like you use the old OpenZwave integration. You should think about migration to Zwave-JS-UI https://www.domoticz.com/wiki/Zwave-JS-UI as Openzwave will be deleted from Domoticz in the near future.
I also see a lot of messages like
That 'Unknown' seems strange.
I've had similar experience with openzwave.
Since switching to zwave js ui it's way better.
Also check in to secure inclusion. S0 causes a lot of overhead.
Switches don't need security imo. Reaction time is much better without security.
