Open Zwave Error 'OZW-driver')) received fatal signal 11 (Segmentation fault)
Knight
Domoticz version: 2024.7
Post by Knight »
I have my first problem with my old Open Zwave network. I cant tell if have done anything but upgrade Zigbee for domoticz.
My domoticz has crash 3 times this day and the last Error is
2024-04-06 22:00:20.400 Error: Domoticz(pid:111573, tid:111592('OZW-driver')) received fatal signal 11 (Segmentation fault)
2024-04-06 22:00:20.400 Error: siginfo address=0x1b3d5, address=0x7f95e109fc
I Dont know what to do. It's an old Open Zwave network...
Domoticz version: 2025.1
Re: Open Zwave Error 'OZW-driver')) received fatal signal 11 (Segmentation fault)
Perhaps an issue with usb mounting. Did you use /dev/serial/by-id names to assign the drives or use eg ttyUSB0?
Knight
Post by Knight »
Thank you! Maybe it is a connections problem. I had an issue with the Zigbee USB controller. I had to reconnect it to the usb cable.
I use Serial RaZberry 2 as controller.
Knight
Post by Knight »
I have turn of Automatic Database backup and no more crashes.. I Hope this solve the problem. Sorry OpenZwave. I dont think OZW is the problem.
Knight
Post by Knight »
Still going strong OpenZwave....
Z-wave netowrk 2024-11-19.jpg (316.94 KiB) Viewed 2728 times
