Domoticz et al. Configuration Files
elzorrovega
Domoticz version: 2025.2
Post by elzorrovega »
Hello All,
Mosquitto and Domoticz 2024.4 are running as local services in a Pi4b with Bullseye. ZWaveJS-UI is running as a service in a Docker container.
Domoticz database stores information such as: device data, application settings, scripts, users, etc. Mosquitto has own file configuration file in /etc/mosquitto/mosquitto.conf.
However, ZWaveJS-UI settings backup is somewhat cloudy. As recommended, created directory /opt/zwavejs-ui and copied file docker-compose.yml which starts-up container. After configuring ZWaveJS-UI and pressing save in settings window some files are written in directory /opt/zwavejs-ui/store/.
Is settings.json backup settings file for ZWaveJS-UI?
Does line ./store:/usr/src/app/store in yml file refer to a docker container directory?
Backing-up all essential configurations files should make it easier for a clean installation.
Thanks in advance.
ElZorrovega
Last edited by elzorrovega on Wednesday 21 August 2024 13:00, edited 1 time in total.
The solution to the problem changes the problem!
Rasberry Pi 4 Model B; Bookworm 64 bit OS 6.12.47+rpt-rpi-v8
Domoticz Version: 2025.2
zwave-js-ui: 10.4.2.d3a89a7
zwave-js: 15.3.1
home id: 3714679688
home hex: 0xdd698388
Domoticz version: 2026.3
Re: Domoticz et al. Configuration Files
elzorrovega
Hello Waltervi,
Thanks for the reply. Removing some kinks after migrating to and reading Z-Wave JS UI documentation, I found the same answer as the post.
zwave-js-ui: 9.9.0.09b107a
zwave-js: 12.4.4
home id: 3714679688
Save settings
Once finished press SAVE and the gateway will start a Z-Wave Network Scan.
Backing Up Settings
Settings, scenes and the Z-Wave configuration are stored in JSON files under the project store folder. It is a good idea to backup those files, which can be done by backing up the store or using the import/export buttons.
/opt/zwavejs-ui/store $ ls
config dd698388.values.jsonl settings.json
dd698388.jsonl dd698388.values.jsonl.lock snippets
dd698388.jsonl.lock logs users.json
dd698388.metadata.jsonl nodes.json
dd698388.metadata.jsonl.lock sessions
Please be aware that if you are using DzVents/BASH scripts to change device parameters or integrating non discovered devices after auto discovery to Z-Wave-JS take into account the Z-Wave JS UI; Setting; Gateway; Topic Type = Name topics or ValueID Topics. This caused me some misery until MQTT Explorer showed the expected message topic structure.
zwave-js: 15.3.1
home id: 3714679688
