lidl lightbulb to be controlled from lidl-app AND domoticz
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi.
Just bought zigbee smart lights from lidl.
I can pair with domoticz
I can pair with lidl-app
but not together
is there somewhere some data for this or isnot this possible?
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2025.1
Re: lidl lightbulb to be controlled from lidl-app AND domoticz
Pair with liddl app? I suppose with Lidl Hub?
A zigbee device can be paired with only one coördinator ( eg Lidl Hub or USB Zigbee stick) on the same time.
BartSr
Post by BartSr »
Walter you'r right. Meantioned 'from app' as it was done via the app.
So far so good. I hoped for some similar to KAKU which has the possibility to control lights both from DZ as well as KAKU remote control. Just to meet WAF factor.
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Instead of the Lidl app you give here the Domoticz app,
Problem solved :-)
BartSr
Post by BartSr »
Lidl lights come with zigbee remote control. Next step to look for integration that one into Domoticz.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Kedi
Post by Kedi »
On the Lidl gateway there is a RJ45-ethernet port.
BartSr
Post by BartSr »
@kedi
I know but that is to use a 'lidl' cloud.
Waltervl informed me zigbee devices can be connected to just one coördinator.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Thorgal789
Post by Thorgal789 »
He is right, but you can have 1 coordinator (so one gateway) managed by an application, that make a public network, and third app can connect to it.
It's like that that work the ikea gateway, or the HUE one, or deconz.
Thoses gateway work in stand alone mode, using 1 gateway, but you can connect on the same HUE gateway, domotiz, your phone, your TV, and Home assistant in same time.
Honnestly I don't know the lidl zigbee network, and if it have an API usable by third app.
There is no interface for the Lidl bridge/hub with Domoticz.
Thorgal789
Not existing don't mean not possible. We are on domoticz ^^, I think it's one the easier application to develop plugin.
Is there a public API for the Lidl bridge/hub? I am not aware of one. If not it will take a lot of effort and alternatives are already available (skip Lidl bridge and buy hue bridge or use another existing zigbee integration)
Kedi
Post by Kedi »
OK, no out of the box API/integration, you have to hack it.
Thorgal789
Yes, it's more complex than for the ikea/philips one.
Less friendly and more dangerous.
