Wifi Weather station possible?
Obelix
Post by Obelix »
Hi All,
I am reading this topics, and it seems that there are a lot of issues with different sensors and stations.
I am wondering if there are any Wifi based weather stations that can be connected with Domoticz?
I am not after a very high end station, just want to use the station to control blinds, curtains.
Domoticz version: 2026.3
Re: Wifi Weather station possible?
Obelix wrote: Thursday 25 February 2021 15:33I am not after a very high end station, just want to use the station to control blinds, curtains.
If you really only want to use it for this purpose a lux (light) sensor is enough. I am not sure about wifi but a lot of zigbee motion sensors also have a lux sensor.
You could also use your solar panels as a light sensor.
But a decent weather station is always nice to have :-). I am curious too is someone advises a reasonable priced device
psubiaco
Post by psubiaco »
Hi Obelix,
I successfully use the weather station WH-2081: wireless weather station with 2 AA NiMH batteries, that communicate (433 MHz?? I don't know) with a palm that can be connected by USB to Raspberry/PC with Domoticz.
It works like a charm.
Full details about configuration at https://www.creasol.it/support/domotics ... d-domoticz
Bye. Paolo
Paolo
Obelix
Post by Obelix »
Thank you Paolo,
I am going to check this one out!
solarboy
Domoticz version: 2026.4
Post by solarboy »
]The link above is dead. It is now at
https://www.creasol.it/en/support/domot ... d-domoticz
Intel NUC with Ubuntu Server VM (Proxmox),mosquitto(docker),RFXtrx433E,zwavejsUI (docker),Zigbee2mqtt(docker),Harmony Hub, Kodi,APC UPS,SMA Modbus,Broadlink,Dombus
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
May be this will be helpful to you.
I made such project.
It is WiFi and shows real temperature, humidity, atm.pressure very good.
Coast about - $6-$8
habahabahaba
Or you can make Dummy hardware, create virtual sensors and take weather conditions you need from OpenWeathermap.
habahabahaba wrote: Saturday 09 March 2024 20:45 Or you can make Dummy hardware, create virtual sensors and take weather conditions you need from OpenWeathermap.
Or use one of the build in weather services https://www.domoticz.com/wiki/Weather
Kedi
Domoticz version: latest
Post by Kedi »
The problem with those build-in weather services is, that they don't have really local weather.
I experienced it myself for my sunscreen.
So I bought an Alecto WS5000 and now I have real local weather from by backyard.
Now I know when (local) wind gets too strong for my sunscreen, and I raise it in time.
Indeed your own weather station is better. There are some Alecto ones that can be used, see https://www.domoticz.com/forum/viewtopic.php?t=21248
