Is it possible to make a dial in dashticz for a selection switch with the values from -5 to +5?
The appearance in the form of: Show multiple values of a P1 meter in the read document. (https://dashticz.readthedocs.io/en/beta ... /dial.html)
In the form of a dimmer with the + and - (up / down) and the value in the middle would also be nice.
I can control the heating curve of my heat pump with the selector switch (works via Domoticz)
Thanks in advance.
Dashticz - dial - selector switch from -5 to 5
- Domoticz version: 2026.3
Re: Dashticz - dial - selector switch from -5 to 5
Just to inform you that latest stable Domoticz versions now have a configurable setpoint device. So instead of a selector switch you can create a setpoint device from -5 to + 5 with step size 1. It could be easier to have that displayed like your wishes in Dashticz...
https://www.domoticz.com/wiki/Dummy_for ... t_Setpoint
Lokonli
You can create an up/down dial and set min to -5 and max to 5.Garfield wrote: Friday 01 March 2024 10:17 Is it possible to make a dial in dashticz for a selection switch with the values from -5 to +5?
Thanks in advance.
Is that what you want?
Garfield
- Domoticz version: 2024.4
@waltervl, @Lokonli
Both options work!! Thanks
