I have devices known as ts130f to drive my blinds and
It seems that inverting position doesn't work in domoticz (Perhaps it is not 'reverse position' (i translate from french, sorry))
Via Zigbee2MQTT it works in the right way ( Expose, open et close)
So i have two blinds that go in the wrong way. Whatever 'reverse position' is active or not. I need to click on 'open' to close.
So if my blinds are opened and if i click on close nothing happens but in the logs i see :
Zigbee2mqtt.log :
info 2024-02-19 19:29:27MQTT publish: topic 'zigbee2mqtt/Volet TV', payload '{"backlight_mode":"ON","calibration":"OFF","calibration_time":25.9,"indicator_mode":"off","last_seen":"2024-02-19T18:29:27.869Z","linkquality":255,"motor_reversal":"ON","moving":"STOP","position":100,"state":"OPEN"}'
info 2024-02-19 19:29:27MQTT publish: topic 'zigbee2mqtt/Volet TV', payload '{"backlight_mode":"ON","calibration":"OFF","calibration_time":25.9,"indicator_mode":"off","last_seen":"2024-02-19T18:29:27.879Z","linkquality":255,"motor_reversal":"ON","moving":"UP","position":100,"state":"OPEN"}'
info 2024-02-19 19:29:28MQTT publish: topic 'zigbee2mqtt/Volet TV', payload '{"backlight_mode":"ON","calibration":"OFF","calibration_time":25.9,"indicator_mode":"off","last_seen":"2024-02-19T18:29:28.363Z","linkquality":255,"motor_reversal":"ON","moving":"STOP","position":100,"state":"OPEN"}'Code: Select all
2024-02-19 19:28:09.930 ZigBee2MQTT-Deconz: [Command] Device 0xa4c138457c37891b(1): Open(level = 0, color = )
2024-02-19 19:28:09.940 ZigBee2MQTT-Deconz: Command "Open" from device "Volet Télévision (Position)"
2024-02-19 19:28:09.940 ZigBee2MQTT-Deconz: MqttClient::publish zigbee2mqtt/Volet TV/set ({"state": "open"})
2024-02-19 19:28:09.907 Status: User: admin (IP: 192.168.0.120) initiated a switch command (210/Volet Télévision (Position)/Close)
2024-02-19 19:28:10.805 ZigBee2MQTT-Deconz: [Command] Device 0xa4c138457c37891b(1): Open(level = 0, color = )
2024-02-19 19:28:10.822 ZigBee2MQTT-Deconz: Command "Open" from device "Volet Télévision (Position)"
2024-02-19 19:28:10.822 ZigBee2MQTT-Deconz: MqttClient::publish zigbee2mqtt/Volet TV/set ({"state": "open"})
2024-02-19 19:28:10.798 Status: User: admin (IP: 192.168.0.120) initiated a switch command (210/Volet Télévision (Position)/Close)
2024-02-19 19:28:14.131 Status: EventSystem: reset all device statuses...
2024-02-19 19:28:18.611 ZigBee2MQTT-Deconz: [Command] Device 0xa4c138457c37891b(1): Open(level = 0, color = )
2024-02-19 19:28:18.626 ZigBee2MQTT-Deconz: Command "Open" from device "Volet Télévision (Position)"
2024-02-19 19:28:18.626 ZigBee2MQTT-Deconz: MqttClient::publish zigbee2mqtt/Volet TV/set ({"state": "open"})
2024-02-19 19:28:18.571 Status: User: admin (IP: 192.168.0.120) initiated a switch command (210/Volet Télévision (Position)/Close)
2024-02-19 19:28:19.627 ZigBee2MQTT-Deconz: [Command] Device 0xa4c138457c37891b(1): Open(level = 0, color = )
2024-02-19 19:28:19.644 ZigBee2MQTT-Deconz: Command "Open" from device "Volet Télévision (Position)"
2024-02-19 19:28:19.644 ZigBee2MQTT-Deconz: MqttClient::publish zigbee2mqtt/Volet TV/set ({"state": "open"})
2024-02-19 19:28:19.598 Status: User: admin (IP: 192.168.0.120) initiated a switch command (210/Volet Télévision (Position)/Close)
2024-02-19 19:28:20.719 ZigBee2MQTT-Deconz: [Command] Device 0xa4c138457c37891b(1): Open(level = 0, color = )
2024-02-19 19:28:20.726 ZigBee2MQTT-Deconz: Command "Open" from device "Volet Télévision (Position)"
2024-02-19 19:28:20.727 ZigBee2MQTT-Deconz: MqttClient::publish zigbee2mqtt/Volet TV/set ({"state": "open"}) Thanks
