Understanding logs about a missing device
capitalT
Post by capitalT »
Domoticz does not show an air quality value or text from my IKEA VINDSTYRKA Air quality monitor.
I want to understand what the logs are trying to tell me here:
Error: DeConz: Unknow device type ZHAAirQuality
Who doesn't know this device type? Deconz or Domoticz?
And to help me a little further, where in the code should this device type have been defined?
Domoticz version: 2025.1
Re: Understanding logs about a missing device
This is a message from the integration. Plugin or MQTT AD. It seems the integration wants to use or create a device with a device type that does not exist. So probably a type error somewhere.
What zigbee integration in Domoticz do you use?
capitalT
Post by capitalT »
waltervl wrote: Monday 19 February 2024 22:06 What zigbee integration in Domoticz do you use?
I use the default deconz plugin. I see an air quality device in Domoticz, so something going wrong in the plugin with the translation, right?
edit: I see that this plugin is from its own repo which hasn't been updated for a while.
Thanks for pointing me in the right direction!
Thorgal789
Post by Thorgal789 »
Try updating your plugin version, this device type is supported since 2022, or there is a problem with this device.
And look if you are on the good github page because the repo is updated 3/4 time by year.
Users browsing this forum: eddieb and 1 guest
