Router firmware https://github.com/itead/Sonoff_Zigbee ... -E/Router
Log from Domoitcz
2024-02-18 19:29:38.540 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 3: 0004 (Groups)
2024-02-18 19:29:38.541 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 4: 0005 (Scenes)
2024-02-18 19:29:38.542 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 5: 0006 (On/Off)
2024-02-18 19:29:38.542 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 6: 0008 (Level Control)
2024-02-18 19:29:38.543 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster OUT Count: 00
2024-02-18 19:29:38.640 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Simple Descriptor Response EP: 0x02 LQI: 200
2024-02-18 19:29:38.640 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a ProfileID 0104
2024-02-18 19:29:38.641 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a ZDeviceID 010d
2024-02-18 19:29:38.643 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Application Version 0001
2024-02-18 19:29:38.646 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster IN Count: 08
2024-02-18 19:29:38.648 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 1: 0000 (Basic)
2024-02-18 19:29:38.648 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 2: 0003 (Identify)
2024-02-18 19:29:38.650 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 3: 0004 (Groups)
2024-02-18 19:29:38.650 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 4: 0005 (Scenes)
2024-02-18 19:29:38.651 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 5: 0006 (On/Off)
2024-02-18 19:29:38.652 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 6: 0008 (Level Control)
2024-02-18 19:29:38.653 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 7: 0300 (Colour Control)
2024-02-18 19:29:38.653 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster In 8: 1000 (Touchlink)
2024-02-18 19:29:38.654 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster OUT Count: 00
2024-02-18 19:29:38.748 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Simple Descriptor Response EP: 0xf2 LQI: 200
2024-02-18 19:29:38.749 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a ProfileID a1e0
2024-02-18 19:29:38.750 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a ZDeviceID 0061
2024-02-18 19:29:38.755 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Application Version 0001
2024-02-18 19:29:38.757 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster IN Count: 00
2024-02-18 19:29:38.758 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster OUT Count: 01
2024-02-18 19:29:38.758 Status: Zigbee Sonoff Cordinator: [-] NEW OBJECT: 638a Cluster Out 1: 0021
2024-02-18 19:29:39.106 Status: Zigbee Sonoff Cordinator: [0] NEW OBJECT: 638a Model Name: DONGLE-E_R
2024-02-18 19:29:39.107 Status: Zigbee Sonoff Cordinator: [0] NEW OBJECT: 638a Manufacturer Name: SONOFF
2024-02-18 19:29:40.602 Z-Wave: Usage (Friggebod relä 2 watt)
2024-02-18 19:29:40.646 Z-Wave: General/kWh (Friggebod relä 2 kWh Meter)
2024-02-18 19:29:42.064 RFCOM STYRENHET: Temp + Humidity (Unknown)
2024-02-18 19:29:42.979 Z-Wave: General/kWh (Fibaro Tvättstuga kWh Meter)
Zigbee for domoticz Plugin issue. device not in databas. Sonoff 3.0 usb dongle -e as repeater
Knight
- Domoticz version: 2024.7
- Screenshot_20240218_180325_Samsung Internet.jpg (45.39 KiB) Viewed 1353 times
Re: Zigbee for domoticz Plugin issue. device not in databas. Sonoff 3.0 usb dongle -e as repeater
This is the expected behavior as when you use the router firmware, there is no actionors, nor sensor. So nothing in Domoticz DB.
