I've still only got two Stella TRVs in a test setup and have had mixed results, the worst of which was when one ran out of batteries while almost fully open while we were away. Nothing I could to apart from watching the room temperature go up and up from 1000km away...
Yes, I had a valve with a flat battery yesterday and the yellow battery warning didn't occur. The valve was open enough to keep heat in the room though.
With my control, if I have a non responsive valve but I see there is a temperature rise in the room (due to other room calling for heat) I can adjust the valve icon like a dimmer and when Domo sees it above 25% it allows the room to call the boiler or below 25% it prevents the call.
Remotely, I have a heating off button (for summer) which I used yesterday to cool the valves for an hour before they would get back into heating and cooling routine after being off all night due to Zwave lockup. In your scenario I could've set the switch timers to 'pulse' the heating.
I'm just writing a script to give me separate room isolation buttons which will set that room to 14oc on the virtual thermometer and adding buttons to add or subtract 0.5oc per push to a room after passing the virtual thermometer to a variable. Also an 'away' button to set all rooms to 14oc with PIRs to set it back to normal operation. Obviously all these buttons could have a timer added or even respond to Google calendar events.
Just sounds like you need to add more control
Once I was away for January and set my old house thermostat to 10oc, before we left my wife put towels on the radiator (to dry, unknown to me) below the thermostat. We came home to a near empty oil tank.
