Raspi 3b running ok for a couple of years now. Buster.
Domoticz Version: 2024.3
Build Hash: 3503953dd
Compile Date: 2024-01-24 08:40:07
dzVents Version: 3.1.8
Python Version: 3.7.3 (default, Oct 11 2023, 09:51:27) [GCC 8.3.0]
Could someone help me with this crashlog file please and give me a clue as to why Domoticz runs for a short while.
It's certainly beyond my understanding.
Thanks for any advice.
[New LWP 15020]
[New LWP 15031]
[New LWP 15039]
[New LWP 15040]
[New LWP 15041]
[New LWP 15042]
[New LWP 15043]
[New LWP 15044]
[New LWP 15045]
[New LWP 15046]
[New LWP 15047]
[New LWP 15048]
[New LWP 15049]
[New LWP 15050]
[New LWP 15052]
[New LWP 15053]
[New LWP 15054]
[New LWP 15055]
[New LWP 15056]
[New LWP 15057]
[New LWP 15058]
[New LWP 15059]
[New LWP 15060]
[New LWP 15061]
[New LWP 15067]
[New LWP 15103]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
__GI___nanosleep (remaining=0x7ef968c0, requested_time=0x7ef968c0) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
28 ../sysdeps/unix/sysv/linux/nanosleep.c: No such file or directory.
Id Target Id Frame
* 1 Thread 0x76ef5040 (LWP 15019) "domoticz" __GI___nanosleep (remaining=0x7ef968c0, requested_time=0x7ef968c0) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
2 Thread 0x759a6200 (LWP 15020) "SQLHelper" __lll_lock_wait (futex=futex@entry=0xcb7e00 <m_sql+232>, private=0) at lowlevellock.c:43
3 Thread 0x751a5200 (LWP 15031) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
4 Thread 0x74374200 (LWP 15039) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
5 Thread 0x73b73200 (LWP 15040) "MQTTPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
6 Thread 0x73372200 (LWP 15041) "Webem_ssncleane" 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x733712e0, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
7 Thread 0x72b71200 (LWP 15042) "WebServer_8080" __libc_pread64 (offset=<optimized out>, count=4096, buf=0x72219630, fd=47) at ../sysdeps/unix/sysv/linux/pread64.c:29
8 Thread 0x721ff200 (LWP 15043) "Webem_ssncleane" 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x721fe2e0, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
9 Thread 0x719fe200 (LWP 15044) "WebServer_443" 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x719fd2d8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
10 Thread 0x70fff200 (LWP 15045) "Scheduler" __lll_lock_wait (futex=futex@entry=0xcb7e00 <m_sql+232>, private=0) at lowlevellock.c:43
11 Thread 0x707fe200 (LWP 15046) "TCPServer" 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x707fd310, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
12 Thread 0x6fdff200 (LWP 15047) "MainWorker" __lll_lock_wait (futex=futex@entry=0xcb7e00 <m_sql+232>, private=0) at lowlevellock.c:43
13 Thread 0x6f5fe200 (LWP 15048) "MainWorkerRxMsg" __lll_lock_wait (futex=futex@entry=0xcb7e00 <m_sql+232>, private=0) at lowlevellock.c:43
14 Thread 0x6edfd200 (LWP 15049) "Watchdog" __waitpid (options=0, stat_loc=0x6edfc350, pid=15379) at ../sysdeps/unix/sysv/linux/waitpid.c:30
15 Thread 0x6e1ff200 (LWP 15050) "RfxCom-tx/rx" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
16 Thread 0x6d9fe200 (LWP 15052) "openweather" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
17 Thread 0x6cbff200 (LWP 15053) "Weather" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
18 Thread 0x6c3fe200 (LWP 15054) "MQTTad" __lll_lock_wait (futex=futex@entry=0xcb7e00 <m_sql+232>, private=0) at lowlevellock.c:43
19 Thread 0x6bbfd200 (LWP 15055) "Domoticz_HBWork" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
20 Thread 0x6b3fc200 (LWP 15056) "ShellyHW" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
21 Thread 0x6abfb200 (LWP 15057) "NotificationSys" futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6abfabb0, expected=0, futex_word=0xcb7694 <m_mainworker+2548>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
22 Thread 0x6a3fa200 (LWP 15058) "Plugin_ASIO" 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x6a3f92c8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
23 Thread 0x69bf9200 (LWP 15059) "ShellyHW" futex_wait_cancelable (private=0, expected=0, futex_word=0x1df1fd8) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
24 Thread 0x693f8200 (LWP 15060) "EventSystem" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
25 Thread 0x68bf7200 (LWP 15061) "EventSystemQueu" __lll_lock_wait (futex=futex@entry=0xcb7e00 <m_sql+232>, private=0) at lowlevellock.c:43
26 Thread 0x67bf5200 (LWP 15067) "RfxCom-tx/rx" 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x67bf42f8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
27 Thread 0x683f6200 (LWP 15103) "WebServer_8080" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
Thread 27 (Thread 0x683f6200 (LWP 15103)):
#0 syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
#1 0x00b4225e in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
#2 0x009f8ef6 in http::server::CWebsocketHandler::Do_Work() ()
#3 0x00b40a8a in execute_native_thread_routine ()
#4 0x76a24494 in start_thread (arg=0x683f6200) at pthread_create.c:486
#5 0x768d7e98 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 26 (Thread 0x67bf5200 (LWP 15067)):
#0 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x67bf42f8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#1 0x00778e90 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
#2 0x0077aa2a in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
#3 0x0077cd96 in boost::detail::thread_data<AsyncSerial::open(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned int, boost::asio::serial_port_base::parity, boost::asio::serial_port_base::character_size, boost::asio::serial_port_base::flow_control, boost::asio::serial_port_base::stop_bits)::{lambda()#2}>::run() ()
#4 0x00a2a0c0 in thread_proxy ()
#5 0x76a24494 in start_thread (arg=0x67bf5200) at pthread_create.c:486
#6 0x768d7e98 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 25 (Thread 0x68bf7200 (LWP 15061)):
#0 __lll_lock_wait (futex=futex@entry=0xcb7e00 <m_sql+232>, private=0) at lowlevellock.c:43
#1 0x76a26f44 in __GI___pthread_mutex_lock (mutex=0xcb7e00 <m_sql+232>) at pthread_mutex_lock.c:80
#2 0x0069cfb0 in CSQLHelper::query(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#3 0x0069d2c8 in CSQLHelper::safe_query[abi:cxx11](char const*, ...) ()
#4 0x00623704 in CdzVents::ExportDomoticzDataToLua(lua_State*, std::vector<CEventSystem::_tEventQueue, std::allocator<CEventSystem::_tEventQueue> > const&) ()
#5 0x006246bc in CdzVents::EvaluateDzVents(lua_State*, std::vector<CEventSystem::_tEventQueue, std::allocator<CEventSystem::_tEventQueue> > const&, int) ()
#6 0x00636942 in CEventSystem::EvaluateLua(std::vector<CEventSystem::_tEventQueue, std::allocator<CEventSystem::_tEventQueue> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#7 0x006372fa in CEventSystem::EvaluateEvent(std::vector<CEventSystem::_tEventQueue, std::allocator<CEventSystem::_tEventQueue> > const&) ()
#8 0x00638336 in CEventSystem::EventQueueThread() ()
#9 0x00b40a8a in execute_native_thread_routine ()
#10 0x76a24494 in start_thread (arg=0x68bf7200) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0x32
Thread 24 (Thread 0x693f8200 (LWP 15060)):
#2 0x00631d98 in CEventSystem::Do_Work() ()
#4 0x76a24494 in start_thread (arg=0x693f8200) at pthread_create.c:486
Thread 23 (Thread 0x69bf9200 (LWP 15059)):
#0 futex_wait_cancelable (private=0, expected=0, futex_word=0x1df1fd8) at ../sysdeps/unix/sysv/linux/futex-internal.h:88
#1 __pthread_cond_wait_common (abstime=0x0, mutex=0x0, cond=0x1df1fb0) at pthread_cond_wait.c:502
#2 __pthread_cond_wait (cond=0x1df1fb0, mutex=0x0) at pthread_cond_wait.c:655
#3 0x0077aaac in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
#4 0x0078b0d8 in boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_scheduler_runner>::run() ()
#5 0x007770ba in boost_asio_detail_posix_thread_function ()
#6 0x76a24494 in start_thread (arg=0x69bf9200) at pthread_create.c:486
#7 0x768d7e98 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 22 (Thread 0x6a3fa200 (LWP 15058)):
#0 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x6a3f92c8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3 0x0097e5b6 in Plugins::BoostWorkers() ()
#5 0x76a24494 in start_thread (arg=0x6a3fa200) at pthread_create.c:486
Thread 21 (Thread 0x6abfb200 (LWP 15057)):
#0 futex_abstimed_wait_cancelable (private=<optimized out>, abstime=0x6abfabb0, expected=0, futex_word=0xcb7694 <m_mainworker+2548>) at ../sysdeps/unix/sysv/linux/futex-internal.h:205
#1 __pthread_cond_wait_common (abstime=0x6abfabb0, mutex=0x0, cond=0xcb7668 <m_mainworker+2504>) at pthread_cond_wait.c:539
#2 __pthread_cond_timedwait (cond=0xcb7668 <m_mainworker+2504>, mutex=0x0, abstime=0x6abfabb0) at pthread_cond_wait.c:667
#3 0x00685fd6 in CNotificationSystem::QueueThread() ()
#4 0x00b40a8a in execute_native_thread_routine ()
#5 0x76a24494 in start_thread (arg=0x6abfb200) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0x74
Thread 20 (Thread 0x6b3fc200 (LWP 15056)):
#2 0x0097bf20 in Plugins::CPlugin::Do_Work() ()
#4 0x76a24494 in start_thread (arg=0x6b3fc200) at pthread_create.c:486
Thread 19 (Thread 0x6bbfd200 (LWP 15055)):
#2 0x007bc6f0 in CDomoticzHardwareBase::Do_Heartbeat_Work() ()
#4 0x76a24494 in start_thread (arg=0x6bbfd200) at pthread_create.c:486
Thread 18 (Thread 0x6c3fe200 (LWP 15054)):
#4 0x0069d966 in CSQLHelper::GetAddjustment(int, char const*, unsigned char, unsigned char, unsigned char, float&, float&) ()
#5 0x0086651a in MQTTAutoDiscover::GuessSensorTypeValue(MQTTAutoDiscover::_tMQTTASensor*, unsigned char&, unsigned char&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, int&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&) ()
#6 0x00866b24 in MQTTAutoDiscover::HaveSingleTempHumBaro(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#7 0x008653e6 in MQTTAutoDiscover::handle_auto_discovery_sensor(MQTTAutoDiscover::_tMQTTASensor*, mosquitto_message const*) ()
#8 0x0086c83e in MQTTAutoDiscover::handle_auto_discovery_sensor_message(mosquitto_message const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#9 0x0086ccc6 in MQTTAutoDiscover::on_message(mosquitto_message const*) ()
#10 0x00a264fe in handle.publish ()
#11 0x00a22326 in packet.read ()
#12 0x00a1f410 in mosquitto_loop_read ()
#13 0x00a1f6ea in mosquitto_loop ()
#14 0x00685aec in mosqdz::mosquittodz::loop(int, int) ()
#15 0x008583c4 in MQTT::Do_Work() ()
#16 0x00b40a8a in execute_native_thread_routine ()
#17 0x76a24494 in start_thread (arg=0x6c3fe200) at pthread_create.c:486
#18 0x768d7e98 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 17 (Thread 0x6cbff200 (LWP 15053)):
#2 0x0084ec70 in CMeteorologisk::Do_Work() ()
#4 0x76a24494 in start_thread (arg=0x6cbff200) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0xc
Thread 16 (Thread 0x6d9fe200 (LWP 15052)):
#2 0x0089b0b8 in COpenWeatherMap::Do_Work() ()
#4 0x76a24494 in start_thread (arg=0x6d9fe200) at pthread_create.c:486
Thread 15 (Thread 0x6e1ff200 (LWP 15050)):
#2 0x00907694 in RFXComSerial::Do_Work() ()
#4 0x76a24494 in start_thread (arg=0x6e1ff200) at pthread_create.c:486
Thread 14 (Thread 0x6edfd200 (LWP 15049)):
#0 __waitpid (options=0, stat_loc=0x6edfc350, pid=15379) at ../sysdeps/unix/sysv/linux/waitpid.c:30
#1 __waitpid (pid=15379, stat_loc=0x6edfc350, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
#2 0x0069a012 in dumpstack_gdb(bool) ()
#3 0x0069a3d4 in signal_handler(int, siginfo_t*, void*) ()
#4 <signal handler called>
#5 raise (sig=10) at ../sysdeps/unix/sysv/linux/raise.c:50
#6 0x0069a612 in Do_Watchdog_Work() ()
#7 0x00b40a8a in execute_native_thread_routine ()
#8 0x76a24494 in start_thread (arg=0x6edfd200) at pthread_create.c:486
#9 0x768d7e98 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 13 (Thread 0x6f5fe200 (LWP 15048)):
#4 0x006d39ce in http::server::CWebServer::GetJSonDevices(Json::Value&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool, bool, long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#5 0x006edfcc in http::server::CWebServer::Cmd_GetDevices(http::server::_tWebEmSession&, http::server::request const&, Json::Value&) ()
#6 0x006d20e4 in http::server::CWebServer::GetJSonPage(http::server::_tWebEmSession&, http::server::request const&, http::server::reply&) ()
#7 0x009d7b9a in http::server::cWebem::CheckForPageOverride(http::server::_tWebEmSession&, http::server::request&, http::server::reply&) ()
#8 0x009fa45c in http::server::CWebsocketHandler::Handle(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool) ()
#9 0x009f905c in http::server::CWebsocketHandler::OnDeviceChanged(unsigned long long) ()
#10 0x0074be2e in boost::detail::function::void_function_obj_invoker4<CWebSocketPush::Start()::{lambda(auto:1, auto:2, auto:3&&, auto:4)#1}, void, int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*>::invoke(boost::detail::function::function_buffer&, int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const, unsigned char const) ()
#11 0x00683a86 in boost::signals2::detail::signal_impl<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*), boost::signals2::optional_last_value<void>, int, std::less<int>, boost::function<void (int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::function<void (boost::signals2::connection const&, int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*)>, boost::signals2::mutex>::operator()(int, unsigned long long, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, unsigned char const*) ()
#12 0x00675434 in MainWorker::ProcessRXMessage(CDomoticzHardwareBase const*, unsigned char const*, char const*, int, char const*) ()
#13 0x00677b8e in MainWorker::Do_Work_On_Rx_Messages() ()
#14 0x00b40a8a in execute_native_thread_routine ()
#15 0x76a24494 in start_thread (arg=0x6f5fe200) at pthread_create.c:486
#16 0x768d7e98 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 12 (Thread 0x6fdff200 (LWP 15047)):
#4 0x0069f738 in CSQLHelper::UpdateTemperatureLog() ()
#5 0x006aca80 in CSQLHelper::ScheduleShortlog() ()
#6 0x00674fa8 in MainWorker::Do_Work() ()
#8 0x76a24494 in start_thread (arg=0x6fdff200) at pthread_create.c:486
Thread 11 (Thread 0x707fe200 (LWP 15046)):
#0 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x707fd310, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3 0x009c1ff8 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<tcp::server::CTCPServer::StartServer(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#1}> > >::_M_run() ()
#5 0x76a24494 in start_thread (arg=0x707fe200) at pthread_create.c:486
Thread 10 (Thread 0x70fff200 (LWP 15045)):
#4 0x00693028 in CScheduler::DeleteExpiredTimers() ()
#5 0x006932ae in CScheduler::Do_Work() ()
#6 0x00b40a8a in execute_native_thread_routine ()
#7 0x76a24494 in start_thread (arg=0x70fff200) at pthread_create.c:486
#8 0x768d7e98 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 9 (Thread 0x719fe200 (LWP 15044)):
#0 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x719fd2d8, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3 0x009f390a in http::server::server_base::run() ()
#4 0x006cc8b0 in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::CWebServer::StartServer(http::server::server_settings&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool)::{lambda()#307}> > >::_M_run() ()
#5 0x00b40a8a in execute_native_thread_routine ()
#6 0x76a24494 in start_thread (arg=0x719fe200) at pthread_create.c:486
Thread 8 (Thread 0x721ff200 (LWP 15043)):
#0 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x721fe2e0, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#3 0x009d54ee in std::thread::_State_impl<std::thread::_Invoker<std::tuple<http::server::cWebem::cWebem(http::server::server_settings const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)::{lambda()#2}> > >::_M_run() ()
#5 0x76a24494 in start_thread (arg=0x721ff200) at pthread_create.c:486
Thread 7 (Thread 0x72b71200 (LWP 15042)):
#0 __libc_pread64 (offset=<optimized out>, count=4096, buf=0x72219630, fd=47) at ../sysdeps/unix/sysv/linux/pread64.c:29
#1 __libc_pread64 (fd=47, buf=0x72219630, count=4096, offset=5747456) at ../sysdeps/unix/sysv/linux/pread64.c:27
Backtrace stopped: Cannot access memory at address 0x4
Thread 6 (Thread 0x73372200 (LWP 15041)):
#0 0x768d82f0 in epoll_wait (epfd=<optimized out>, events=0x733712e0, maxevents=128, timeout=-1) at ../sysdeps/unix/sysv/linux/epoll_wait.c:30
#5 0x76a24494 in start_thread (arg=0x73372200) at pthread_create.c:486
Thread 5 (Thread 0x73b73200 (LWP 15040)):
#2 0x00749472 in CMQTTPush::Do_Work() ()
#4 0x76a24494 in start_thread (arg=0x73b73200) at pthread_create.c:486
Thread 4 (Thread 0x74374200 (LWP 15039)):
#2 0x00745f30 in CInfluxPush::Do_Work() ()
#4 0x76a24494 in start_thread (arg=0x74374200) at pthread_create.c:486
Thread 3 (Thread 0x751a5200 (LWP 15031)):
#2 0x0097ebe4 in Plugins::CPluginSystem::Do_Work() ()
#4 0x76a24494 in start_thread (arg=0x751a5200) at pthread_create.c:486
Backtrace stopped: Cannot access memory at address 0x1ff0b5f8
Thread 2 (Thread 0x759a6200 (LWP 15020)):
#4 0x00639162 in CEventSystem::ProcessDevice(int, unsigned long long, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, int, char const*) ()
#5 0x006a9c9e in CSQLHelper::UpdateValueInt(int, int, char const*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, int, char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, bool, char const*) ()
#6 0x006adc22 in CSQLHelper::UpdateValue(int, int, char const*, unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, int, char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, bool, char const*) ()
#7 0x0067808c in MainWorker::UpdateDevice(int, int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, int, int, int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, int, bool) ()
#8 0x006787c0 in MainWorker::UpdateDevice(int, int, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, int, bool) ()
#9 0x006ab752 in CSQLHelper::Do_Work() ()
#10 0x00b40a8a in execute_native_thread_routine ()
#11 0x76a24494 in start_thread (arg=0x759a6200) at pthread_create.c:486
#12 0x768d7e98 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Thread 1 (Thread 0x76ef5040 (LWP 15019)):
#0 __GI___nanosleep (remaining=0x7ef968c0, requested_time=0x7ef968c0) at ../sysdeps/unix/sysv/linux/nanosleep.c:28
#1 __GI___nanosleep (requested_time=0x7ef968c0, remaining=0x7ef968c0) at ../sysdeps/unix/sysv/linux/nanosleep.c:25
#2 0x006455e4 in sleep_seconds(long) ()
#3 0x005ea528 in main ()
Main thread:
[Inferior 1 (process 15019) detached]
Permanent crashing!
- Domoticz version: 2026.3
Re: Permanent crashing!
Did you look at the troubleshooting wiki? https://www.domoticz.com/wiki/Troubleshooting
It is the watchdog thread so something basic wrong with your environment. Could be hardware related, powersupply, SD card.
Also check your Domoticz log what is happening
willemd
I see memory access errors and therefore would move to a new SD card if I were you.
paul402
OK. Thanks for the replies. I have something to work on.
Kedi
- Domoticz version: latest
memory access errors lines are almost always present in the crash log at any crash of Domoticz.
What is a short while? seconds, minutes, hours, days?
